i am getting charged $440 for a days labour looking for the problem
and a new oxygen sensor fitted. this sounds very expensive to me.
am i getting ripped off?? does anyone know how much a new oxygen sensor is??
i like my pockets fat not flat
BS!! way overpriced.
Genuine sensor is under $200 plus 30min fitting (max) so lets say $80/hr and call it $250 all up
EL falcon sensor I got for $60 and paid an auto elec $50 to wire it in for me as the plug needed cutting etc around $110 all up
$440? did you get a small favour in the back lane as well?
Dude I just fitted a universal 18mm Zirconium type to my GT-t, it works just fine and cost $56 and 15mins to fit. Fitting just involved cutting the plug off the old one, using the supplied crimps to attach the new one.
This is the type I got, they're Highflow brand
http://cgi.ebay.com.au/OXYGEN-02-SENSOR-3-...9QQcmdZViewItem
it took them a day to figure out that the oxygen sensor was stuffed :blink: What exactly was the problem in the first place? That might straighten things out becaase f**k paying over $400 to put a oxygen sensor in!!!! My mate got a oxygen sensor from nissan then drove over to a mechanics and they preety much handed him the tool to do it himself. Obviously they saw no point in charging someone for such an easy job.
genuine is 180 rrp - trade is less. labour - you're talking 10 minutes. you don't even have to take the heatshield off.
I would feel bad charging someone to do that. I'd just do it for free - pr - encourage them to come back next time. or charge then $10 labour or something.
having said that though, you have paid them for some diagnostic time. If your mechanic doens't have a scantool, I wouldn't have got them to diagnose it though. mucking aroudn with a multimeter takes ages, and wastes your money.
    • You guys need to live a little! Nothing keeps the blood flowing like lying under something that could collapse on you at any time! The vast majority of the weight of my car is out of it. There's zero attached outside of the interior of the car. It's pretty much full interior but once I take the front seats out it's just the dash and some of the boot contents remaining. I would guess that as it sits it would be already well under a tonne, even less without the seats.
    • https://www.youtube.com/watch?v=KyZDvZmvhik
    • You'd be better off digging a pit and standing under it to shoot it.
    • The easiest way would to be ignore the oscilloscope, grab a multimeter, and make sure all the main connections are right. An oscilloscope will give 99.9% of even technicians so much grief, as they have no idea what things should even look like on an oscilloscope. Which is also even more likely for someone who's first ever major work on a car is this If the battery volts are dropping down so low, the LDV will reboot the ECU, when it does so, it will drop out the start circuit. If this is occuring, the battery voltage should also come back up. Give it a few tests, even simple ones like when you're attempting to crank it, measure voltage from the engine block, to the negative terminal. You might find you've got really bad connections somewhere. My guess is the "new" motor has something like a shit starter motor, at which point, you can swap the starter motor from the old motor, to the new motor. Before I did any of the above though, I'd 100% confirm the battery in the vehicle. Most jumper packs are absolutely useless, especially if a battery has a bad cell for example. Also the new modern "jump packs" if you don't know what you're doing with them, you won't even get them into high current stage. So go back to basics, check the battery, especially with a known good one as a replacement test. Check ALL the wiring, this includes where they're bolted onto the battery, and bolted onto the starter motor. Check all the earth straps are on. Measure your resistances across your earth straps. A good check here is to measure voltage across the earth straps while you're trying to crank it. If you're seeing voltage, you've got high resistance joints! Oh, and once you've done the above, check the battery over again.
