in fact i like these brakes so much I bought another set for the other car on the weekend. 356mm set this time, with a minor adjustment to the dogbone adapter we got it to fit under our weds 17" wheels too
  • Replies 116
I just wanted to post somewhere in here that I have now had the opportunity to use the "race" pads that Just Jap sell for the G4's. I have standard rear brakes with BEndix Ultimates in there and find that not only is there no bias issues, I have fixed a bias issue that I believe the car has from factory. I was regularly cooking rear rotors and pads before but now it all runs fine. Lap times are down and the car stops amazingly. I was regularly braking far too early due to being used to the standard setup. With the addition of good tyres and these brakes I knocked 3 seconds off my previous pb at Wakie.
Thats awesome. You were quick before from memory, so you are into the 1:07s or something now? Though i have to ask, what tyres? Tyres are worth 2-3 seconds at Wakefield, so be interesting to see you run the same tyres as you used to and see if there is any difference in lap times at all. Thats not to take away from the fact that the car is much easier to stop and nicer to drive.
1:11's on new enough RE55's and 1:08.5 with old 2nd hand slicks. My shocks are totally stuffed so if I can find some money for a rebuild of them I will go and have another crack. I nearly came in my pants every time I did a 1:08 so imagine how excited I'll get if I pull a 1:07.9999999!
So you are 2.5 seconds quicker on old slicks compared to relatively new semi slicks? That goes agaisnt the trend of typical time improvements for tyres. I suspect the RE55s were cactus as i would have thought a 250rwks R34 on RE55s would be quicker then 1:11s? Slap some new suspension in and decent RE55s and i suspect you will match/better then slick times!?!?!??!?!?!
LOL, actually no. Sober at present :) Just getting dumber by the day. :P You did you say "With the addition of good tyres and these brakes I knocked 3 seconds off my previous pb at Wakie"
LOL...sorry, just saying thats huge, but with swaybars in the mix as well it starts to paint a picture that makes more sense :)
Oh damn, maybe I forgot to mention the sway bars.
From my hazy memory I was running mid 1:11's with RE55's, then high 1:11's with sway bars, brakes and streeters, then mid 1:08's with sway bars, brakes and old slicks.
  • 4 months later...
Hi all great read, r33 gtst - anyone had clearance issues with wheels 356mm kit 18" wheels tried spacers still no good might hav to get wheels machined a little, tried two sets of wheels speedy inferno 18x8, and ROH drift R 18x8.
cheers skuzzas
I've run the 365 brakes under 17" rims without spacers, so it is the design of the rims that matter not the diameter.
In particular rims with "dish" just won't clear good brakes
Just re-reading the above, i cant believe how brakes can bag you 3 seconds, especially around a track like Wakefield. I mean think about a car that is 3 seconds slower at the drags and the distance between them when they are travelling over 150km/h. I cant see any brake upgrade allowing you to pull that sort of time difference from simply slowing the car a few meters deeper under brakes
The problem with Drift Rs is that they have "cheater dish" - where the end of the spoke curves in before contacting the barrel. It's the only way high offset wheels can get any lip at all.
Roy, I believe the tyres would have had a huge impact on the time.
Brakes to improve your time as long as you use them correctly and get on the gas quicker. Your lap times will slow if you are heavy on the brakes and hard on the acceleration because the distance you are covering at speed is reduced dramatically compared to a proper entry and exit with a constantly increasing throttle.
I agree regarding tyres, but i have simply read too many articles and have fiddled with enough brake setups to confidently say that the difference is on the 4th lap when you simply have too much car for the std brakes and everything is getting toasty hot
The only major improvement i think you see with bigger brakes is consistancy. SO a 3 seconds over a number of laps i can easily believe. Over a single lap, being your best lap of the day.... well i am just still a little sceptical of such claims.
Suspension setup and tyres play a bigger role in stopping distances then the caliper/rotor arrangement. There are many back to back tests that show stopping distance improvements of less then a car length from std equip using good pads and fluid compared to big dollar Brembo/AP/Alcon setups. Where the big setups help is that they operate at lower temps so are more consistant
  • 4 months later...
Any idea if they will be able to be run with 33 gtr wheels + spacers? Or am i better of getting the 330mm g4 set-up? :down:
cheers
Grab the 356mm setup and if your 17's dont fir then get some TE37 or something that have better brake clearance
So your saying go for the 356mm set-up, the 330mm doesn't really add up as an effective upgrade? I was hoping to not upgrade the wheels, everything adds up so violently.. motor, turbo, fuel set-up :D the wallet.
Going to measure the diameter of the wheel today, hopefully that's all Il need a 20-30mm spacer should stop it from hitting the spokes (as it's not a dished rim the spokes are set out more to the outer edge of the wheel), will report my finding
In the grand scheme of things the 330 and 356mm setups are pretty similar in price. And considering you have a big heavy GTR with plenty of grunt i think you are really better served with the 356, especially since there is a range of 17" wheels that will swallow them. Just need to flog off your current wheels to help fund the better 17" wheels.
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
    • Just wanted to say thank you for your input   my man (lead mechanic by trade) and I have done a heap of work as you can imagine just to make the hot side work with the dump pipe, stupid massive intake on turbo, trying to get the waste gate on was not fun.  I’m kinda getting to the point where I don’t know if I try and make this work and not throw all this cash and time away or do I scrap the lot and start again? the Apexi I’ve got was tuned for a few slight differences:   Tomei pon cams (mine are stock neo) Turbo smart 38mm external waste gate (mines 45mm replumbed) with stainless screamer pipe  3inch turbo back exhaust with high flow cat Sard 800cc top feed injectors Sard adjustable fuel pressure reg
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
