Thanks Roy, might just have to wait till the car is back out of the shop before I dive into another aspect of the car. Will keep everyone posted.
Edited by Tomek
  • 1 year later...
  • Replies 116
Duncan any chance you have tried to fit 17" drifteks over 356mm fronts?
I am seriously thinking about getting a set considering
R33 Gtr calipers say $1800
new discs $700
pads $300
braided lines $200
=$3k
And I think I have found a place that will do 356mm + 330mm kits delivered for $3000
mods? not sure what you mean?
I have a set of 356mm on the 350z (well did, I just sold it) for about 2 years, straight bolt on, no problems.
I have a set of 356mm on the new race car but it hasn't run yet. straight bolt on.
I have a set of 330mm on the stagea under 17" rims. These have been running for at least 3 years and are second hand off my race car. 3rd set of pads, first set of rotors, absolutley no issues. I did have a minor issue with installation, it is a 32 gtr kit with m12 bolts but the stage hub allows m14 bolts. Added a small sleeve. Also had to trim the brake backing plate.
aleks, sorry not sure but you would need VERY generous internal size to run 356 under 17s. The only one we got to fit, and only by 1mm was a set of weds. Also required adjsutment to the caliper mounts and the caliper, but it was a race car so who cares. In practice....330 17"+, 356 18"+
  • 4 weeks later...
Great read. I am considering going down the brake upgrade path myself as i encounter fade on my weekend mountain runs..
What is a 356kit actually worth? And i also plan on upgrading my wheels to 18x10 +18 all round Work XD9's, i know these are the "dished style" of rim.. is anyone running a 356mm on these wheels?
What are the chancing of these clearing a 356mm kit front / rear..
Also best place to source these? Just jap?
Cheers!
  • 8 months later...
I have done a bit of research on these Taiwanese big brake kits and it appears that they are not all the same... although they have the same origin (an old AP design)
At least in the case of K Sport they are an independent company that make a lot of budget motor sport parts and has put in a lot of their own R & D into these brake kits.
In doing so they have developed a better performing and higher quality product than the others.
In the UK and Europe heaps of people use these K Sport big brake kits on serious track cars and rave about them... even after swapping over from Brembo's!
They are also supplied there and in the US by very reputable brake shops who would not be risking their reputation by selling crap brakes.
I have just ordered the 8 pot, 330mm kit from JustJap at a very sharp price; in fact only a couple of hundred more than a 330mm, 2 piece, rotor upgrade kit using OEM calipers!
Apparently the pads they come with are pretty useless but they are a standard pad size used by AP calipers and I have sourced some decent ones locally already.
Will provide some feedback once I've hit the track but bang-for-buck these K Sports cannot be beat.
Cheers Checkbuzz
Did you uncover anything interesting about the PB kits while you were researching the K Sport kits?
Does anyone have any experience (good or otherwise) with the PB kits?
K-sports/D2 are all the same dude as they come in exactly the same box and so on. You'd take a fair stab it's the same factory.
Do you have hard evidence to suggest otherwise?
Hope you didn't pay too much though (PM me the price if you want). The KSport GB i've been trying to get off the ground looks like it might almost be possible :D
Either way they certainly cannot be beaten for the price.
Scotsman recently did a 1:19 around Sandown with 320rwkw or so and those brakes. Obviously with uprated pads. Proof is right there in my books and he's done a number of track days now without an issue
It's basically the same deal as our Wilwood kits. They are not ADR approved (most overseas brake brands aren't - GREX, HKS etc), however can be engineered/mod plated if installed properly and legal brake lines used.
Yes there are a lot of peeps running K-sports here in the UK.
I upgraded to R33 Brembos though because they fit my needs of casual track plus they look better. ;)
Ash is right.
I actually did a lot of research into these prior to doing the Wilwood group buy. I even got in contact with one of the guys in Taiwan that sends these kits out.
From what I found they all pointed to a couple of factories in Taiwan that manufacture brake kits.
Suppliers than sell them under their own name.
There are even more brands (heaps more) that none of you guys would have heard of other than the commonly available G4/D2/K Sport that they trade under, such as Nashin, Kido, G force, JUN etc (see pic).
Basically if you ordered a certain quantity as a supplier (for example 15 kits) you could get what ever colour, style of caliper and writing you wanted on them. Even some different choices in rotors. So for example white calipers with SAU written on them :P They could even do a 12 piston caliper kit with 400mm x 36mm rotors!
If you knew the prices of some of these kits in larger quantites you wouldn't believe me.
I even spoke to one of my mates about getting money together and designing our own kit to supply in Australia - but we weren't to keen to send $15,000+ to Taiwan lol.
At the end of the day it wasn't something I was interested in but the proof is in the results, they work well.
They are cheap and nasty but if they do they job ok I suppose that is ok?
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
