They are cheap and nasty but if they do they job ok I suppose that is ok?
How are they nasty exactly? Because of the colour?
If they have been proven on club level circuit cars to be perfectly fine then they are fine for anyone else at that level too. Perhaps at the pinnacle/upper end there might be some difference that warrants a price tag 3x the amount.
When you consider what the equivalent Alcon setup costs - you could buy TWO sets of these (say one dies in 3yrs) and still be infront.
Some stuff outta china/taiwan is certainly rubbish and i'd say away too - however the brakes seem to be fine and are in use on a good number of cars doing some very fast times.
  • Replies 116
I went brand whore with brakes and I regret it.
When I sit and look at what I got for not much short of 5 k for fronts only my arse starts to bleed.
Given the time over and the testimonials of those using the alternatives I would have no qualms in saving a shitload of coin and using them myself.
I have been running the G4 356mm kit on my R33 Gtst circuit car for 4 Years.(running 440kw)
The only thing I didn't like was the supplied brake lines, but i had new ones made up.
I have just replaced the rotors after 4 years of use.
bang for buck they are great.
You got 4 years out of a set of rotors with 440kw? Holy shit... :O
What type of pads? They couldn't have been very agressive?
My DBA4000's lasted about 5,000kms with DS3000 pads and that was just street driving and the old owner doing i think 2 track days.
But yes agree - brake lines probably an issue. Most people already have them anyway. I will reuse the ones i have.
Only 12 months with 440, was mostly 300.
I have only ever ran the G4 green race pad. They work really well.
The pad they come with outta the box? :O
I've heard they are no where near as harsh, and hence don't stop as well as more agressive pads so that would make sense as to why you've had some decent life.
Also a GTS-t so there is less weight etc. Not a bad life survival - I'd certainly expect a lot less based on past experiences with many rotor/pad combos :D
any one the best place to get front and rear Ksport brake kits?
Rear seems not to matter. Infact people leave the stock rears in most cases I've seen
JJap have them in stock - But give me a month, I'm getting pricing for the GB. If it isn't decent/worthwhile then i won't bother.
I also want to get a kit and trial it mself to ensure it fits 100% first from the supplier chosen. Nothing worse than getting them and it's all fked up.
They come with the street pads which are shit, but they also have a race pad.
It's funny. Read through this thread, the people who put shit on these brakes have not used them. Everyone who has used them says they are good, including some really harsh use like rallies and racing. Pretty simple odds.
I always run the supplied pads in mine, I got the kit from Just Jap and they had a choice of street, sport or race pads. I run the race pads on the race car, and sport in rallies or on the street. No problems at all and I still haven't had to replace rotors (I have replaced pads a few times).
will you be fitting them on your gtr nismoid?
id be interested in a GB if the improvement over 33gtr brembos was big enough
Yep. My own car will be guinea pig.
Although that said the owner of Racepace has D2's on his GTR that have run fine at ALL the track-days attended (he's even run PB's since installing brakes) over the last year and this is what's convinced me i might as well as im looking to upgrade.
Although I'm getting them via a different supplier and they are KSport - although no real difference.
The advantage will be going up in rotor size as I'll be getting the 356mm kit. Not even going to waste time with the 330 as IMO just stick with stock brembo's for that as ksports do not offer much of a gain. It's the larger overall that is viable from what ive investigated.
Plan is to be going from Brembo/OEM 330mm DBA4000/DS3000 to KSport 356mm/DS3000
I'll update more when its all done and dusted.
Interested in the 356mm
  • Like 1
DS3000s are really abrasive cold, so even though they bite well, they destroy rotors when used for street. EBC yellows dont bite well cold but they dont eat rotors either. I dont know how they compare back to back for track work, because i've only ever used the golds with my G4 330s (and was happy with them - only about $320 for set plus a little grinder work to make them sit deeper in the caliper so they didnt overhang the rotor).
Well apart from chatter on UK websites from brake specialists they do a pretty convincing job in the brochure that came in the box; including photo's of their CNC mills, brake balancing and durability machines etc at their 13000 square meter factory in Taiwan where they "engineer and manufacture high performance shock absorbers and brake systems"...
So no hard evidence I guess, just lots of very convincing stuff.
I can't comment on the other brands except to say that K Sport seem to rule in the UK and US where D2/G4 don't appear to be as popular.
Either way my new K Sport kit was delivered today and it certainly looks very well engineered & packaged!
I'm happy with what I paid for the kit which was considerably less then the on-line advertised price
I've also got some slotted DBA4000's, Hawk pads and new seal kit for the rears plus RB74 pads for the 8 pots so braking should be well and truly sorted!
FYI - Some one I heard of got the rear K Sport kit as well as front but ended up having to use a brake bias valve to stop the rears locking up all the time so they may be a bit over kill.
I got quoted $4500 at one place for a K Sport full 330mm front and rear kit which keeps the factory handbrake set up but I think it's a bit too much. With the bigger front rotors etc the rears tend to do even less work. Stock size rear rotors, calipers and decent pads should cover it for most street/track purposes at a fraction of the cost.
Good luck with the GB dude.
K-sports/D2 are all the same dude as they come in exactly the same box and so on. You'd take a fair stab it's the same factory.
Do you have hard evidence to suggest otherwise?
Hope you didn't pay too much though (PM me the price if you want). The KSport GB i've been trying to get off the ground looks like it might almost be possible :D
Either way they certainly cannot be beaten for the price.
Scotsman recently did a 1:19 around Sandown with 320rwkw or so and those brakes. Obviously with uprated pads. Proof is right there in my books and he's done a number of track days now without an issue
Edited by Checkbuzz
  • 1 month later...
Well I guess all the research in world can't beat real life experience and I am very disappointed with K Sport.
At the end of the day you only get what you pay for and when it comes to K Sport that means a poor quality product and zero customer service/warranty support even when purchasing through a large retailer such as JustJap
One of the brake rotors supplied had a run out at least 0.1mm (Nissan and K sport both specify 0.05mm is the maximum allowable run out) so after spending hours removing studs and cleaning up the hub assembly asssuming the problem must be with my car I measured the hub which was with in tolerance <0.02mm, marked the high point on the disk rotor, turned it 180 degrees only to find that the high point was still the high point i.e. it was the disk that was out of tolerance!
OK everybody makes mistakes right (although I'd argue that brake component manufacturers do not really have this luxury) so I contact JustJap who are very helpful and organise a courier pick up of the disk and it's return to K Sport.
K Sport call me and I give them a run down of the problem, they say they wil look at it and see what they can do...
A few days later the very same faulty disk rotor that I sent them is returned with; no paper work or any other repair information and the same run out problem!
I am out of pocket $2K, my car has been off the road for over a month and I am f**king pissed off!!!
Your goods are not "fit for purpose" so I suggest you take the kit back to JustJap and get your money back. They have to return your money if i understand the Trade Practices act, or whatever its called these days.
Seems odd to me that ksport got involved with you - IMO you should just deal the JJ. I would insist on that if i were you.
FWIW, I am a happy JJ and G4 brake customer.
  • 5 years later...
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
