I think it has more to do with getting an even force across the entire pad. 'Stilhetto effect' doesn't really apply because the piston pressure is applied to the pad which is then applied to the rotor via the surface area of the pad, not the pistons. That was worded really poorly.... what I'm trying to say is any pressure applied to the pad from the pistons is spread over the surface of the pad acting on the rotor. Even pressure means even heat dispersion and less prone to frying brake pads.
Yep... thats it... :)
  • Replies 116
Yeah, but 6 bigger pistons is going to have more surface area, which in turn would produce a more even spread of pressure. Im not knocking the idea of 8 tiny pistons, I just find it a bit strange. Like 6 pistons means less expencive rebuilds etc. 4 pistons less again.
Alcon made 16 piston calieprs that ran on 2l Super Tourers. Its more to do with the piston size, the differential size between leading and trailign pistons etc that all helps ensure even pad pressure and temps. It help stops glazing hot spots etc etc.
hows is the handling of the car affected by the new brake setup? I would say with having much bigger disc's and huge 8 piston calipers that there is going to be a lot more unsprung mass as well as gyroscopic force.
Honestly if i had to guage it it would be 5/10 on the f**k all meter.
Rotational inertia has distance^2, there for having weight that is firther out is far worse. Looking at the disc sure its a bit firther out, and a bit heavier, but look at the tyre and rim, its huge compared to the disc in diameter and quite hefty.
so for arguments sake if you have 5 kg at 20 cm radius its 0.2 kg m^2
then we take 5 kg at 40 cm radius its 0.8 kg m^2, you can see a 4 times increase.
Rotational inertia (Properly called the second moment of area - I) is measured in mm^4. As in Torque = I * alpha where alpha is angular acceleration measured in radians per second squared. This is the rotational equivalent of Newtons famous Force = mass * acceleration.
The only reference I have ever seen to the direct effect on steering was in reference to the Indy cars where some drivers noticed a change in steering effort due to a change in gyroscopic effect when they changed the material the rotor was made out of. This was at rather ridiculous speeds, however.
What a heavier rotor/caliper does do is add to the unsprung weight of the car which affects the ability of the suspension to keep the tyre on the road. This is something to be avoided if possible.
Does anyone have the weight of a standard 4 pot caliper and rotor, as i will weigh my 356mm G4 set to get a comparision.
I have some pics of the second set of pads as i think Roy noted he would like to see the wear of these but cant post any pic for some reason.
I also noted last night the the leading pistons in the G4 caliper is quite a bit larger than the 6 trailing ones.
If anyone can tell me how to post pics now i will bang them up for all to see
  • 5 weeks later...
Just wanted to mention in here that we are running the G4 brakes without any problems, including Targa Tasmania last month - their performance has been excellent.
There was an offset problem with the early kits which meant that the caliper was rubbing on the lower control arm ball joint, but anyone affected has been sent new brackets and hats which fixed the problem.
I've had no issues with the brackets or bolts at all.
Mine are on atm....but I think the overall volume of the pistons will be similar to stock - which is one benefit of the calipers - you don't need to change the master cylinder.
As discussed above the biggest benefit of more pistons is spreading the force more evenly across the pad and to change leading/trailing pressures.
An 'even spread of pressure' would also depend on the rigidity of the calipers, the more the calipers flex the more uneven such pressure will be. No matter how many pistons the caliper has.
Those G4 calipers have a very open and long bridge which is unsupported, unlike eg Stoptech calipers. My bet is that those G4's flex quite a bit.
Okay...
So whats the final answer on these brakes?
This thread seems to lean more towards dont get them, as they are a waste.
The other G4 thread says nothing but praises about them however.
I need to know for sure as I was going to order these a few days ago for my high power GTR33.
Get them or pass and pay the extra for a name brand pair? As I said above, this is for a high powered GTR33.
-Sayajin
from a bystanders veiw
they seem like a good calliper and rotor senario.
but their was the issue of:
-bracket bolts-(fixed with the help of a spring washer and nut.have you thought towards a loctite and split pin setup?)
-aftermarket pads-fixed by machining the top edge a 1mm or 2.
My R33
G4 brakes (356mm disk, G4 'street' pads): 130 degrees
Standard rear brakes (Nissan OEM pad) 280 degrees
Another R33
F40 Brembo brakes (340mm disk, Ferrodo 2500 or 3000 pads): 300 degrees
Standard rear brakes (pad unknown): 150 degrees
R34 GT-T
CSC brakes (343mm disk, Ferrodo 2500 or 3000 pads): 150 degrees
Standard rear brakes (pad unknown) 80 degrees
they obviously are up to the task.
Either way ducting,the best fluid and regular upkeep/brake and its assemblies seem to be the norm.
in conclusion:-
when they are compared to the other brakes,the temps are good.and given that they have had track and targa testing i can only see the plus's outweighing the negatives.price is also good.
if i were in your position i would lean towards them.just do the right thing and use the knowledge and experience that others have given you.
Craig.
well...people who haven't used them or who spent 3 times as much to buy a "name" brand recommend against them.
People who have used them think they are excellent.
Ben had a strange problem with the brackets that no-one else has reported so it could just be a one off.
Fact is there are a lot of people in the world who don't beleive cheap can ever = good. Feel free to spend far more than you have to :)
i have them, and i have used them as their sole purpose as brakes for a track car. Car is good enough to run with porsche GT3, ferrari 599, 430 360, aston DB9, BMW M3 csl with AP brakes etc but cant catch them bloody Z06 corvettes they are seriously fast.
I have them so far no issues i am worried about. 3 sets of pads used with good wear pattern, been off and on many times and still bolt up perfectly. You will need to duct air to them as all brakes require if you are going to push the car to 100% of it performance
As far as i am concerned i would buy them again.
Edited by tacker
yeah.im sure that the name brand ones are better than the generic aftermarket equivelent.but not every1 has the cash to fork out.thats where these are good.
aside from the obvious problems.as i am sure every good brake manufacturer endless,harrop and the rest etc has had teething problems with.these are pretty good at an entry level point of veiw.
good write up. worth noting is using a bolt/nut would mean going down a size so it fits? or just a longer bolt with a nut aswell?
and it seems the fact the pedal is harder means theres less fluid area (force) being put to the pad compard to the standard one wich in turn will over heat the rears.
and the tru test is to get them red hot (literally) a few times and see if they crack :)
    • Bit of an update to this one. Having some issues on the dyno that held us back (boost spiking) and I want to pass some info over you guys and see what you think is wrong with my setup. The current readout on this dyno is 462rwkw on a low reading dyno so keep in mind it is a real world 500rwkw setup on a hub dyno. Don't read into the power figure too much as a sign of the issue. The short and curly of it is: 2.8 Litre Racepace build RB25 NEO N/A Head with VCT (internally standard however ) Borgwarner EFR 8474  Turbosmart 50mm Straight Gate + Mac valve 6Boost Manifold 4" dump to full 4" exhaust (nil restrictions) Wastegate plumbed back in and all angles in the exhaust system are acceptable and not too sharp. GFB SV52 BOV in cooler piping  Turbosmart BOV in EFR Housing   The issue we are having is it comes onto full boost for example at 4000rpm and spikes to 24/25psi, before dropping down to 17psi before slowly rising back up to the target boost of 23psi. It was extremely uncontrollable and the tuner actually had to ramp in boost progrssively with each 1000rpm on each boost setting we selected to try and reduce the amount of spiking. Sometimes we would see a drop of 10psi from the peak at the beginning of the run, to the low, until it took the next 500-1000rpm to stabilise back up to the target boost. The tuner is pretty confident that the straight gate is just a poorly designed product and leaks too much boost upon cracking the gate open and theres no way to fix it other than going to a poppet valve. He's also confient theres no ignition breakdown or floating valves. The fueling is extremely stable as well. Turbo speed is somewhere around the 109,000rpm area. The spanner in the works for me is that prior to this Borgwarner and StraightGate, the car was tuned on -5 twins at a diferent tuner, and he also had issues controlling the boost with it spiking around the same rpm range, so to me this sounds like the same issue and it can't be anything on the turbo side as this was all changed and I think the behaviour is extremely similar, if not the same. We also removed the mac valve and did a run on wastegate pressure and it still spiked and had the same behaviour. My thoughts on possibilities are: Boost Leak VCT Cam Gear isn't reliably activating consistently - (On this however, we did a run with the VCT disabled and the boost still spiked) Turbosmart BOV is not handling the boost? However this seems unlikely to not be able to handle 20psi. I have a couple of logs that I can't make sense of if anybody knows how to read them and can obtain further logs of other parameters if they are not enough, happy to pay for anyones time. The dyno readout with the power figure is the most recent last week. The other picture is from two weeks prior to that where we couldn't break 400kw (we removed the cat), however the issue of the boost control persisted. @Lithium @Piggaz @burn4005 @GTSBoy @discopotato03 I've tagged those that were quite active in recent pages here, no disrespect to those that know turbos well but I missed tagging. Cheers
    • I recently purchased a 2018 Infiniti Q60, which has an SD card navigation map. I can see my system has options for real time traffic updates etc, and am wondering if there is something I can purchase to get this working? I can see there are at least updated maps for USA and Canada, but nothing for Australia. Surely Infiniti took changing road systems and city expansions into account when they decided to use an inbuilt navigation over Android Auto/Apple Car Play, or are we doomed to drive on streets that don't exist in the navigation system if you drive to a new area?
    • Luckily I didn't put in etch primer as I just found out it's not compatible with my body filler lol. Also just need to sand the panel anywhere between 150-400 grit so I'm in the clear there. It does say to not apply to soft old paint, I assume that means paint that is flaking, peeling,etc
    • @dbm7 and @GTSBoy thank you both very much! will give that a shot!
