  • Replies 116
Under hard driving on the street you feel a bit more confident but in reality you are traction limited long before the brakes run into problems even with a quality standard sized setup, so it's not really possible to experience anything extra the G4 kit might give you.
I think it worth emphasizing this point, the tyres are the limiting factor in braking performance in most Skylines, not the brakes themselves. If maintained properly, the standard 4 spot front and 2 spot rear brakes are more than capable of outbraking the best/biggest road tyres you can buy.
:kiss: cheers :D
  • 11 months later...
As far as multipiston theory goes... I always thought it was to give greater leverage on the rotor for the same diameter of rotor. In a racing series brake diameter is limited by wheel size or regulation. You can run bigger rotors by running low profile calipers but also the further out you put the pad the more leverage it has.
Anyway just a theory I made up, so feel free to ignore it. I drew something in MS-paint using the pad on my laptop but then gave up cause it was too hard. Anyway just based on Torque = Force x Length it made sense to me.
Thats partly it. The other is a longer pad means more surface area of pad which helps with lower pad temperatures meaning less need for craxy high temp pads. Also the fact that the narrower pad means for a given rotor diam you have a shallower pad which allows you to run a narrower steel rotor with larger alloy hat reducing unspring weight. Also the larger pads means you have less localised heating of the rotor which at high temps can help with the onset of rotor warping. Then you have the more even pad wear...there are a whole bunch of reasons. If i wasnt drunk i could think up some more :wave:
I had the opportunity to look at a set of these last week and I was surprised at how small the mounting hardware is. Grossly undersized in my opinion, flex just waiting to happen. Bolts coming loose is a telling symptom of that problem.
Cheers
Gary
Does anyone have the measurements of these calipers, or a spec sheet?
The design is a knock off of an AP from memory, if I can't get the measurements, does anyone know which caliper they copied?
Cheers
Dane
ok well if u guys have only ever heard of these g4 brake calipers coming loose ive seen worse.
r33 gtst here where i live fraser coast has a set of alcon 8 pots front and 6 pot rears. it was driving along behind him and the right rear suddenly locked up solid flat spotting the good ol nankang lol. now like i said alcon like 8 grand of brake front and back and one of the bolts thats hold the caliper to the original bracket had come out and the whole caliper flicked up hitting his 19inch chrome wheels. i couldnt help but laugh at the time cuz all he did was take the caliper off put a set of vice grips on the line and drive it home. either way moral of the story never blame the equipment until proven guilty. and yes loctite always comes in handy.....
now im not saying u didnt do a good job at tightening ur bolts either ok so dont have a go lol.
Cheers
Dane
I've got a pair of Monobloc 8-piston Brembo's & before they went on the car I put them on the bench side-by-side with a pair of the D2's. From memory they were pretty much identical as per the piston spacings & overall dimensions etc although the pics of the G4's at the start of this thread appear to have a large leading piston & 3 small trailing pistons whereas my Brembo's are staggered big-small big-small.
The other big difference apart from the monobloc construction vs the 2-piece construction of the D2/G4's was where the D2's use on single pad per side, my Brembo's use 2 pads per side with the ability to "quick change" the pads out thru the top so they are effectively 2 sets of 4-piston calipers sharing a common body & hydraulic circuit.
They def seem to be a "knock-off" but whether they copied Brembo directly with regard to the piston specs or copied the AP's which in turn copied the Brembo's (but went to a single pad to avoid patent-infringement etc), I don't know.
...whereas my Brembo's are staggered big-small big-small.
... my Brembo's use 2 pads per side with the ability to "quick change" the pads out thru the top so they are effectively 2 sets of 4-piston calipers sharing a common body & hydraulic circuit.
Thats why your caliper does the big small, big smal differential piston sizes, because as you noted you effectively have two 4 piston calipers in one with you running the two pads. If the caliper only used 2 pads, one each side you would expect the traditional small leading and larger trailing pistons
I upgraded to these from the 33/34 brembos. the brembos are rubbish for such a heavy car with so much go. the g4s are 21mm bigger slotted discs, calipers are bigger and lighter, and the pads are about 20% bigger too. No comparison
Great write up, thanks for taking the time!
Guys are the stock GTR brembo's really that bad?? Most people say the stock 33GTSt calipers are much underestimated, and the GTR brembos have got to be a yard ahead of those surely?
Im planning a top end brake upgrade for my GTR and conveniently upgrade my GTS-t with the old brembos front and rear at the same time.
The OE GTR Brembos are pretty good calipers. Problem is when people ask the money they do for them. Its the whole supply and demand thing. There are some other attractive options when you are looking to pay $1600 odd for front calipers with used rotors and pads.
And as far as OE Brembos the Nissan caliper is behind most others fitted to EVOs, STIs, Jags etc
the G4 can take a AP 6pot pad as i got some from from a guy in the BTCC.
As far as i can tell they are a thing of beauty for the money got 2000 kms out of the last set of rotors and its a track only car. I was more than please as they lasted the same amount of kms as my mates RBA 5000 on my mates EVO track car
  • 2 months later...
I just wanted to post somewhere in here that I have now had the opportunity to use the "race" pads that Just Jap sell for the G4's. I have standard rear brakes with BEndix Ultimates in there and find that not only is there no bias issues, I have fixed a bias issue that I believe the car has from factory. I was regularly cooking rear rotors and pads before but now it all runs fine. Lap times are down and the car stops amazingly. I was regularly braking far too early due to being used to the standard setup. With the addition of good tyres and these brakes I knocked 3 seconds off my previous pb at Wakie.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
