Hi guys!
Just wanted to give you a heads up before I post this anywhere else.
I'm selling my JVC head unit for $700
I initially bought it for around $1200-1300 a few months ago (February?) and installed it on my 33 and runs like a dream.
Click here for features
6.5" Full Colour TFT Screen, 5.1 Dolby Digital/DTS/Pro Logic Decoder, DVD Audio, SD Memory Slot, MP3/WMA/WAV/JPEG/MPEG1/MPEG2 Compatible, DVD-R/-RW/+RW/VCD Compatible, Dual Zone, Gold Plated Input/Output Terminals/Ready for IPOD. Excellent Condition and complete with all leads and Terminals.
The reason I'm selling it is because I'm in the market for a single din head unit
Gimme a bingle...! or a PM..
Edited by S T A R 3 3
https://www.sau.com.au/forums/topic/167161-sold/
Hi guys!
Dammit!
I just bought a new head unit :P
This is what I'm hoping to upgrade to in the future
https://www.sau.com.au/forums/topic/167161-sold/#findComment-3095241
I will match the $550 offer and as I was the frist to reply with an offer I belive I am the first in line to buy it.
Please send me more detailed pics to [email protected]
I can be contacted on 0400261099 to arange details.
Cheers
David
LOL
if you were the first one to offer $550 you would have been the first one in line.
free bump.
good luck with sale.
https://www.sau.com.au/forums/topic/167161-sold/#findComment-3105687
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
