was at a mates cusins house the other day and he was showing off his new r34 GTR. he was reving it on idle and he was doing that thing in 2f2f where the R34 is pumping out nos gases into the crowd.
absolute stunner looked insane. i was wondering what kind of work is involved in doing this and how expensive?
ill try get a vid of it next time, honestly hottest thing ive seeen.
if u guys dont know what i mean check this vid out (i know its real corny but it gets to the point)
http://www.youtube.com/watch?v=C27BjrjDkks...ted&search=
Edited by anDru
https://www.sau.com.au/forums/topic/167170-nos-spray/
I still don't get the point of venting valuable nitrous to the air, other than bleeding the system of air... and if it was supposedly only for that, then it shouldn't last that long anyways.
If you want it purely for wank factor, then just get a compressed tank of anything (diving tanks?) and plumb it up with a solenoid... then when you press a button it'll "vent".
https://www.sau.com.au/forums/topic/167170-nos-spray/#findComment-3093269
Get a Co2 purge kit mate, same as nos but not as costly .. obviously is just tanks of co2 linked to a purge/overflow hole which blows it out the side ..
nos wont be in the system so u have no nos benifit.. but u have the wank ability and thats whats important rite :P
AKA fake nos
Edited by DECIM8
https://www.sau.com.au/forums/topic/167170-nos-spray/#findComment-3093520
eh? last time i checked this wasnt ns.com :wave:
https://www.sau.com.au/forums/topic/167170-nos-spray/#findComment-3093902
its a purge kit for the nos!
kind of pointless if you dont have a nos system althou if you just wanted it for looks, you could buy the purge system and hook it up to a c02 bottle and it would do the same thing. add some die into the line and you will get the colour too
how much are these purge systems? any idea wat sort of ppl can do this? also i know its illegal to have NOS injected into your car, but is it legal to vent it like this?
https://www.sau.com.au/forums/topic/167170-nos-spray/#findComment-3094232
Its illegal just to have nitrous in the car
Let alone use it or try and get 15yr old girls excited
https://www.sau.com.au/forums/topic/167170-nos-spray/#findComment-3094522
It probably isn't illegal to vent it if it isn't hooked up to the engine at all, the main problem is that it is a waste of NOS (which, correct me if i'm wrong, isn't cheap). If you are going to all that effort and spraying out proper NOS, wouldn't it be better to hook it up so it actually does something, then when people call you an absolute wanker, you can whip out a vid of you actually using NOS on the track or something.
https://www.sau.com.au/forums/topic/167170-nos-spray/#findComment-3094855
so how do you transport it?
Law:
"a road registered vehicle fitted with nitrous oxide must have the
system modified so that the bottle is properly secured in the brackets
provided and isolated from the engine (disconnect the main braided line
from the bottle), and the supply line to the engine is physically blocked
off with an approved A-1 Performance disarming kit whilst the vehicle is being street
driven."
https://www.sau.com.au/forums/topic/167170-nos-spray/#findComment-3094871
    • It will give gains, but you wont hit 600 It will give gains but it wont get you to 600 imo. You will also sacrifice low down and you will be adding extra volume if you port match it, more so if you port the plenum runners depending and how its done I think the only time youre going to see about 100hp gains is if the car is making well over 1k kw I do have a spare set that I was going to test with, but i dont actually think there is anything worth getting going larger. I did a fair few S14/S15 and the standard TB is fairly small, I went to 60 and in some cases 64mm which is significant over the stock unit. You can also get some weird ratio changes. I think 20kw will be a stretch on a roller dyno. If I had it apart I might mill the shafts a little and not expect much, I think the stock size is still pretty good for a street/track car even with larger capacity. I might change diameter it if its a drag only car
    • Was going to say something about flog, wife, pilates, behind but I better not... No dishonour here
    • Store bought, like dis  https://racecraftaus.com/products/muffler-oval-new?variant=39611886305393
    • As long as the bucket stays against the cam then it will measure up fine, the valve will close compared to a running engine but the bucket will stay against the cam lobe
    • I feel like i would be like most people who get these, excited for the first 3-6 months and then just totally forget about it. The end products do look sick tho. Ive got a 1/12 scale r32 model, dunno where im gonna actually display it once its all done!
