Hey Guys,
Im going traveling OS very soon and need to sell ASAP
PM/Email for high res pics if seriously interested
For sale: 1999 R34 GTT
Asking price: $23500
Kilometer’s: 60xxx
Transmission: Manual transmission
Rego: 11 months left !
Engine type: RB25DET NEO
Color: Black
Modifications: Basically stock, Catback, Pod filter and turbo timer
Not a cent to spend
I have recently had my license cancelled by the RTA for 12 months and would love to keep my car buy unfortunately its not feasible to do so. I am also traveling overseas soon and need to sell the car ASAP
I have recently spent $2000 on servicing the car and have had a new Excedy heavy duty clutch installed, New brake pads, full service including NGK iridium spark plugs and all fluids etc changed
This car is completely stock besides a cat-back HKS exhaust and a brand new Apexi pod filter
Car is in excellent condition and has not skipped a beat since I have owned it. Crystal clear xenon headlights (Not yellow like some). I have always used minimum 98 octane fuel in it
Contact details:
Contact me here – PM etc
Mobile: 0404 159 281
Email: [email protected]
Any tests welcome.
All serious offers considered
Cheers James
Edited by Beauie
Hey guys,
Unfortunately i dont have a license anymore so trades are out of the question (If i had my license i would be keeping it)
I will get you guys some pics ASAP
Lots of interest... Keep the PMs coming :P
  • 3 weeks later...
  • 3 weeks later...
    • There are certain tasks, like replacing head gaskets, where it is very much best to already know what you are doing, and if you are not already an expert, then the next best thing is to have an expert around to help it get done. Little annoying checks and steps that are easy to forget or not interpret the results of properly, etc etc. It is hard to convey that to someone as a lesson prior to taking on a job, because there can be a whole list of "if you see this then it means that", or "if this is what you find then you will need to do these other 4 steps first". All the little bits of knowledge around sealant choice (ie, sealant at all? or no sealant? sealant only in certain parts of the gasket? sealant for this type of gasket but not that type of gasket? etc etc) cleanliness checks and methods, surface straightness and finish checks and methods, etc etc, all combine to mean that people who have done many of the same type of job will struggle less to get a good result than someone who hasn't done it before. I've been around this stuff since forever. But I will still consult with my expert(s) before taking on the big stuff with higher risk profile.
    • Well if I end up having to do the head gasket I will certainly find the necessary tools and instructions before beginning... Let's hope it won't come around.   Definitely. Depends on the job but I think "if you want it done right, do it yourself" applies almost every time
    • Can you at least move to a location without so many ladders, black cats and mirrors precariously propped up ready to be knocked down? Or buy yourself a 1 ton bulker bag of salt to drag around with you. Just, you know, sling it over your shoulder?
    • Meh, what's the worst that can happen? If is is supposed to have a washer, and: the spring retainer seals reasonably well on the surface, maybe just allowing a little bleed of oil out, and the spring does not coil bind when compressed that little extra bit, then the end result will be slightly higher relief pressure setpoint, and no other noticeable effects.
    • Weirdly I see a flat washer on aftermarket pumps but as you said it doesn't seem like new OEM pumps have it. EPC doesn't break out the regulator as a separate component either. I'm guessing if the pump came that way it's safe to use as-is.
