  • Replies 67
the r33 is faster stock, and with similar mods.
handling. both in perfect condition - i'd hae to say the 32. having said that though, in terms of it being faster, that's only provided the components are in good condition (momst of which aren't, the average 32 being 3-5 years older).
having said that though, the 32 is not THAT much better in terms of handling. few mods on the r33 will see it quick (most cars aren't stock anyways).
https://www.sau.com.au/forums/topic/167183-33-vs-32/#findComment-3093077
Drive both and decide for yourself. I drove several 33 gtst and a few 32 gtst's and decided I could live with the lag (for a while) on the 32 but I felt it was a much more spritely drive (although my car has coilovers etc so it's not quite stock handling wise) :P
https://www.sau.com.au/forums/topic/167183-33-vs-32/#findComment-3093517
33 for sure.
why would Nissan release a new model that was inferior?
when it comes to non GTR skylines each new model has out done the one before.
R31<R32<R33<R34<V35
(I would include GTRs here personally but someone will no doubt bring up 1/4 mile times)
https://www.sau.com.au/forums/topic/167183-33-vs-32/#findComment-3093525
33 for sure.
R31<R32<R33<R34<V35
Thats HIGHLY debateable
https://www.sau.com.au/forums/topic/167183-33-vs-32/#findComment-3095594
CBF
But to say each car out did the one previous is very general and I dont think that is an accepted fact.
For one, I personally think the R33 styling was inferior to the R32 from every angle and I am not alone.
We arnt talking about styling though we are talking about the mechanical side of things. It has been stated many times over that th R33 was more of a step sideways than a step forwards. Why would a car manufacture release a new model that isnt superior to the previous model? Perfect example is ford going from the EL to AU styling wasnt widely accepted but it was a superior mecahnically to the later.
https://www.sau.com.au/forums/topic/167183-33-vs-32/#findComment-3098934
agreed. r33 is faster despite the fact that they're slightly heavier. re: looks, both are nice in their own unique way.
https://www.sau.com.au/forums/topic/167183-33-vs-32/#findComment-3099163
Its not unheard of. Case in point - The current Holden Barina is inferior to the model it replaces, as Holden have obviously decided a lower priced/lower quality car will better suit the marketplace.
https://www.sau.com.au/forums/topic/167183-33-vs-32/#findComment-3099668
CBF
Would I be right in guessing that R32 GTS-t owners who have never owned a R33 GTS-t be the ones thinking that?
If thats the case, I dont know anyone with a R33 who would EVER consider buying a R32 GTS-t.
Broken a/c vents, no torque, weak geaRboxs etc etc.....
The R32 vs R33 debate will seemingly never be put to rest.
Long live the BIG whale which, in the GTS25t coupe form, is only 80kg more than the R32 GTS-t but has the extra torque and power of the RB25...
https://www.sau.com.au/forums/topic/167183-33-vs-32/#findComment-3100325
Not a great comparison, the Japanese, in the early-mid 90s, did not make vehicles to "better suit the marketplace" by having lower priced or inferior vehicles.
The R33 GTS25t retailed for about $24100 in 1993 when first released.
The R32 GTS-t retailed for about $19000 in 1989 when first released.
The R33 was not an inferior vehicle, however, it was when the R34 GT-t was released AND interestingly enough, the base model R34 GT-t 5spd retailed at $24100 in 1998.
***Not that any of the above matters. Simply drive both vehicles and see what feels right for you, because on here there are far too many one eyed R32/R33 fans. The pro and cons can be discussed but at the end of the day, you want a car best suited to what you want.
Edited by _8OO5TED_
https://www.sau.com.au/forums/topic/167183-33-vs-32/#findComment-3100332
It was not a comparison, I was answering his question but I guess you missed that bit.
Edited by r32line
https://www.sau.com.au/forums/topic/167183-33-vs-32/#findComment-3100412
The R32 has better handling from very similar suspension geometry but less weight. The R33s suspension was revised to spread the load on the upper control arm over a larger area resulting in the bushes lasting longer.
R33 has superior engine though.
Which is faster is another matter, are you talking lap times, straight line or something else? Lap times are hard to say as there are a lot of variables.
But straight line, simplistically R33 is ~5-6% heavier but has ~16% more power, so R33 is faster.
Edited by salad
https://www.sau.com.au/forums/topic/167183-33-vs-32/#findComment-3104667
Hahaha, i dont agree with that statement at all. You cannot apply rules like 16% more power but only 6% more weight means its faster... I know the R33 is quicker (in a straight line) but just because one cars power to weight ratio is better than another cars it does not mean that car is going to be faster. How a car puts its power down introduces countless other variables....Tyres, AWD vs RWD vs FWD, Traction control system, launch control.... I wont bother continuing
https://www.sau.com.au/forums/topic/167183-33-vs-32/#findComment-3105572
    • My Neo turbo only went last year. Not 35 years old, to be sure - closer to 25. But still.
    • There's no way they left the factory like that. In R chassis there is nothing stopping the steering wheel being put on one spline out from straight, and then adjusting the steering arms to "correct" it (sort of). As well as the indicator cancelling there would also be an issue with how tight you can turn in one direction to the other. The other (less likely) possibility is that the "clock spring" (the circular electronic part that allows the wheel to turn while still having an electrical connection for horn and any other buttons like cruise) might not be in place correctly. I don't have any pics of the R33 (or Stagea) setup but there would be a circular locating tab which sits in the steering column to have it straight...if that is not seated properly then the indicators may not cancel at the right point (and, you might also get a HICAS error since it would think you are driving in circles)
    • It will mostly be bad scoring on the bores, which you can almost certainly fix by machining for oversize pistons. I have to say, I am super surprised that any standard turbos made it 35 years down the track before exploding!
    • Thanks for the info mate was thinking 255/35 rears and 235/40 fronts
    • What's the difference? I would have said that between the front and rear axle lines, there's no noticeable diff between a GTR and an NA 2-door.
