West,
Pivot sell 2 types of shiftlight (that I have seen), one is a small led type with a hideaway box where you make the shift point adjustment, the other is a monster tacho type light only with hide away unit. Most Autobarn stores sell them now. A good alternative to having a huge gague in ure face IMO. Around $199 and $299 respectively.
boli
The HKS Type 1 Turbo Timer has a 2 stage shift light as one of it's features. It is easily adjustable, and makes a noise also when you hit the limit you've set. Great value with it's other features for $300 (if you want to spend that much). I understand you can also get shift lights that hook into the cigarete lighter. Haven't had any first hand exp. with these, but they wire into a control module, where you can manually adjust the limit. I think Autobarn sell them. I've seen one wired into an S15 - looked pretty damn sweet. The light itself is small, and easily concealed.
Good luck
46n2
    • At least you're now aware of the problem and can come up with a solution.
    • Dang. Keen for further updates when you get to it.
    • Welcome to SAU Thomas, sounds like you'd had a bit of a an unlucky start with the car, hopefully you get some better luck now!
    • 1. No need, it only gets used once then is locked in place by the nut 2. EN-62 point 6 shows the conical washer the other way around (BTW I know we discussed above, I hope you are changing the idler as well, while it is no guarantee the bearing is a actually bad, it looks terrible) 3. I'm not really clear on the question, are you worried because it was easy, not hard, to remove the custom timing trigger? As long as it doesn't spin on the crank (when the bolt is tight) all good 4. Yeah just make sure the brand is easy to read as it rolls past 5. The part number is on the listing under the description, 13023-42L00. Given there is a custom part on there for timing (presumably outside the cover), they may have decided to leave that off; I think I would put the washer in there as it also helps seal the timing case from crap getting in.
    • Hey everyone, I recently bought myself a 2001 Nissan Stegea M35, and I've had a few issues that I had to fix, my car would start intermittently and I had a bad rocker cover leak, after a couple days of looking I finally found a part number that interchanges with the OEM starter as the OEM starters at $1300 and I can't afford that, this starter was only $270 and I replaced the start and still had the same issues, I posted a video asking for help online and it went very well, some guy said it was probably a bad ignition switch so I took my dash apart and turns out my ignition switch was half screwed in and was loose, once it was tightened it fired right up, I found a local place called "Boost factory" and they sold me a part of OEM Nissan rocker covers, they were $600 which was a shocker but I couldn't find them anywhere else, so I installed them and fixed my oil leak as the old rocker cover was cracked and warped, I now need to replace my boost air inlet hoses as they have some cracks.
