Correction, worlds quickest street legal car.
Fastest is top speed (I may be wrong)??
Do they mention the TOP speed of that thing?
Callaway Sledgehammer - Worlds Fastest Street Legal Car - 254.76 MPH
Bugatti Veyron - Worlds Fastest Production Car - 253.2 MPH
Dont forget this a veyron GT which might be faster again. Im not sure tho as I havent seen any stats on it.
Yeah i remember see this a while back, but seriously i would prefer the veyron uses a bit less fuel...drives better...and pulls chicks better, and of course it has 11 radiators.
the bugatti might get to its top speed quickest BUT the 2005 Hennessey SRT-10 Viper Venom 1000 Coupe IS THE FASTEST PRODUCATION CAR IN THE WORLD!
people and their f**ken bugatti's, bugatti this and bugatti that.
compare the two....
first is the f**king bugatti
price $1 440 000 USD
engine Aluminum, Narrow Angle W16
position Mid Longitudinal
aspiration Quad Turbocharged
valvetrain DOHC 4 Valves / Cyl w/VVT
displacement 7993 cc / 487.8 cu in
bore 86 mm / 3.39 in
stroke 86 mm / 3.39 in
compression 9.0:1
power 746.5 kw / 1001 bhp @ 6000 rpm
hp per litre 125.23 bhp per litre
bhp/weight 490.45 bhp per weight
torque 1250 nm / 922.0 ft lbs @ 2200-5500 rpm
redline 6500
drive wheels 4WD
body / frame Aluminum Panels over Carbon Fibre Monocoque w/Aluminum Front Subframe, Hybrid VCarbon/Stainless Steel Rear Subframe
front brakes Ventilated & Drilled Discs w/ABS
f brake size 401 mm / 15.8 in
rear brakes Ventilated & Drilled Discs w/ABS
r brake size 381 mm / 15.0 in
front wheels F 50.8 x 28.4 cm / 20 x 11.2 in
rear wheels R 53.3 x 36.6 cm / 21 x 14.4 in
front tire size 265/680ZR500A 99Y Michelin Pilot Sport
rear tire size 365/710ZR540A 108Y Michelin Pilot Sport
f suspension Control Arms w/Coil Springs, Anti-Roll Bar
r suspension Control Arms w/Coil Springs, Anti-Roll Bar
weight 2041 kg / 4500 lbs
wheelbase 2710 mm / 106.7 in
front track 1715 mm / 67.5 in
rear track 1618 mm / 63.7 in
length 4463 mm / 175.7 in
width 1999 mm / 78.7 in
height 1212 mm / 47.7 in
transmission 7-Speed DSG w/Haldex Clutch
top speed 407.2 kph / 253 mph
0 - 60 mph 2.6 seconds
0 - 100 mph 5.7 seconds
0 - 1/4 mile 10.3 seconds
TOP SPEED 253MPH
and now the dodge
price $225 000 USD
engine Venom 1000 90 Degree V10
position FFront Longitudinal
aspiration Twin Garret Turbos
valvetrain Pushrod Activated OHV, 2 Valves per Cyl
fuel feed Electronic Sequential Injection
displacement 8554 cc / 522 cu in
compression 9.0:1
power 745.7 kw / 1000 bhp @ 5000 rpm
hp per litre 116.9 bhp per litre
bhp/weight 291.55 bhp per weight
torque 1491.4 nm / 1100 ft lbs @ 3800 rpm
drive wheels RWD
body / frame SMC & RIm Panels over Tubular Steel Spaceframe
front brakes Brembro Vented Discs
f brake size 356 mm / 14.0 in
rear brakes Brembro Vented Discs
r brake size 356 mm / 14.0 in
front tire size P265/35YR-18
rear tire size P335/30YR-20
f suspension SRT10 KW Adjustable Suspension System
r suspension SRT10 KW Adjustable Suspension System
weight 1556 kg / 3430 lbs
transmission 6-Speed Manual
top speed 410.4 kph / 255 mph
0 - 60 mph 2.9 seconds
0 - 100 mph 5.9 seconds
TOP SPEED 255MPH
compare the weight/torque...hell, even compare the price tag
Edited by thorpe84
i dont know about you guys but to me a STREET LEGAL car has full interior i.e seats,seat belts, dash center console etc etc it also doesnt include full tubs,chute, transbrake... lets be realistic about wtf a street car is ffs.
bugatti is not even 2nd... 1988 callaway sledgehammer corvette tt v8 :)
on the subject of worlds quickest car eg 0-60mph .... here it is tada...
viper
yet again dodge viper power with a little help from hennessey purpose built to take the veyeron -- and yes street legal!!!!
Edited by minger
theres heaps of drift cars registered as a 2 seaters so means missing all of the rear trim myself included.
street legal drag cars run transbrakes and linelockers without a fuss.
its only because the oz government are such retards that they dont allow tubs etc.
if only they were like my old mate helen clark :laugh:
    • Looking at finally painting and installing my R32 GTR wing I bought back in 2018. I got two quotes: Quote 1: $880 includes: wing, spare boot, holes welded up prep/paint. Pro: full boot with wing AND hole-less boot with lip i can swap between Con: $$  Quote 2: $330 wing only. Pro: cheaper Con: lose my (relatively) rare no holes sedan boot Also to consider I do plan on painting my whole car at some point "soon" (been saying that since 2018) Anyway Enjoy these All Japan Day 2025 pictures of my 4 door, still rocking the Calsonic Livery! Rolling in Interior shot Matching Peer Pressure Racing overalls are pretty cute ngl. This year was a hard 1990 cut so I got to be over with all the older cool stuff Next to arguably the best car there. A mighty S-Cargo
    • I personally would run 2x from the cam covers into the catch can, 1x sump vent to catch can (would mount this at a low point of the catch can, so it can also act as a drain). I would see if you can run a -12AN down there to improve venting and also draining. The head drain thing, just drain that back to the sump on the other side. Catch can to be vented, unless you plumb or back to the intake.
    • Yeah the head "drain" is rather a sump/crank case vent. My catch can stopped filling up after venting the sump to the catch can. I have 4x fittings in mine, which is about 5Ls. 2x cam, 1x sump vent/catch can drain, 1x fitting back to the intake and a massive breather which can be blocked so it's a fully sealed system.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Right, here's a video of the basic operation at least.  This is what you can expect day to day when you turn the car on and it boots from standby.  The only thing from a media point of view I haven't gotten working is for it to autoplay plexamp when it turns on from standby (it works from cold boot) but that's more of a plexamp problem as it will autoplay other music players.  Also attached is my one stray cable.  It's part of the screen's wiring adapters but there's just nowhere for it to go in my car.  I've just now done a bit of research and found a matching port on a 2010-2014 head unit with BOSE.  Mine has no BOSE so that's that case pretty much closed I think.  Plugging in the Infiniti AC panel basically did nothing for me, so that's a dead end as well.  Next port of call is to mess with this CANBUS module and see what I can find from it.  I found this resource containing the DBC files for a 2010+ G37 : https://github.com/icecube45/Dash_InfinitiG37/blob/master/InfinitiG37.dbc I'll now have something to go from when I try to extract my CANBUS data so I can see if the HVAC Mode, Fan Speed, Temperature, etc. match and also the gear shifter position.  It's a pretty big assumption that it's just mismatched CAN signals but considering all the devices in the CAN network are talking to each other (AC can be fully adjusted just with no info on screen) it might be a safe one.  I will report back WhatsApp Video 2025-02-26 at 12.49.10.mp4
