  • Replies 46
Originally posted by DennisRB30
Gives the some of the manual boys somthing to think about!  Good work :)
I'm thinkin those time are a little ordinary. I ran my R33 manual and got 14.3@98mph with a shrapnel 2.4 60'. The only mods were a 3" cat back and pod run on 205 tyres. No fmic, boost, or fornt/dump pipe.
The car made 126rwkw on BMT's "conservative" Dyno in the above form.
I think the auto is kinda wasting your time.
Off course a well driven manual will be faster. I was just thinking of a "post your time" thread where only a handful of the manual boys managed to into the 13's, so in that respect a 14.1 is not a bad effort...
What does the snow button do?
well i am also ashamed of my hp output but am happy with the way it goes. r33 gtst 93 running 12 psi, cat back 3 inch, k&n pod i made 203hp at the wheels but ran a [email protected]. Car seems to feel faster than the 203hp but thats what i got and oh well. Friends got an auto 33gtst. Havent raced him yet his is standard with a 3inch cat back. It looses traction nice n easy of the mark.
sweetr33, thats a nice time mate.
mick. i have an auto with similar mods to yours.
3"dump into a high flow cat then 4" race all the way,no bends!
Trust front mount, the big one:D
turbo smart $100 jobbie set to 9psi
HKS pod
dynoed at SAS 170rwKWs
Gtech'd at 13.8 on shitty silverstones 235/45/17s. reading seems to be very consistent as before the Trust goes in i got flat 14s@E/creek then well under all the time.
this was a couple of years ago. now the car is just a work daily driver
what do you guys think i will do at the track now?
street tyres of course
Originally posted by Bo0sT_JuNkY
ive gotta auto r33 gts-t ,with a 2.5inch rear muffler,fmic pod it dynoed 158rwkw.The exhaust is really holding it back to the point that every 1 psi drop's 8/9 hp !!And with a Safc it couldnt make ne more power.I found out it had a melted cat aswell .But it still doesnt seem to make good power for a r33 .But off the mark its a rocket good old snow button.And before u say its bad to use the snow button,I hate auto and if i brake it then my dad will put a manual in :wave:
Well my friend dynoed his 95 man gtst with full hks super drager system hi flow cat,hks filter n 10psi ( Thats stock with no boost controller,must be good exhaust) He got 164rwkw and thats a dame fast stock car and has beatn a 95 with same mods but 15psi.I think the dyno at this place is gives a lower readings than other's they probly do it to make u spend more money there .lol
    • Middle seat good for a slab of beer or Esky for a road trip. 2x kids, means 1x free seat lol.
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
