KILLER-T=dyno queen
YAY!!!! well done Adam! I know the feeling of a low dyno reading! ever since motorvation i sometimes have to rething the situation when going onto a dyno at an event.. motorvation dyno was about 30rwhp too less and then at auto salon due to the difference in air pressure in the dome my car starting pinging through 3 quarters of the run!
Man that must be reading low!! yours is doing about 330 - 340 rwhp yeah? *Mmmmm DROOL*
Guest KILLER-T
Yes it was good to show the trevs what a jap car can do and this trev with a new turbo ford realy wanted to win. Does the first run didnt make enough power to win so he gives me this smug look walks up to his car and turns up the blead valve. Another run still not enough power now he is looking pissed off walks back to the car turns it up a bit more next run the engine hits boost cut man he looked pissed off MMMMwahahahahaha it was funny shit:bahaha: :bahaha: :bahaha: :burnout: :burnout:
Originally posted by R34
Well done mate
good to edukate them V8 drivas.
Any 5.8 holdens? If so what did they produce stock?
What did the Ford Turbo do
Cheers
Chris
LOL there was a 7.5L 460 BBlock XD there. Everyone was goin Phoar this is gonna pull hard. it made a total of 8hp less than my dad. who came third in the 6 cyl class with 218rwhp. which i think must be higher than that if that dyno reads low :P
Overall winner was a black new series holden ute. 412hp was very impressive to see. and the ford xr6T pulled 233hp with boost upped as high as it would go before boost cut
Psiker
    • No intention of driving the car the way it's set up now, just wanting to make sure I haven't made any mistakes along the way so that the tune can go smoothly, I don't want to waste anyone's time with stupid issues. And of course I intend to get it towed to the dyno in a completed state 😅 I have the base fuel pressure with the vacuum disconnected set at about 40psi, which I believe is at least relatively close to stock fuel pressure, maybe I'll have a fiddle with the reg and see what happens. For all I know I could be wasting my time with this and I should just plumb it in and see what the tuner reckons. I just find it a bit strange that it seems to be under so much load just free revving, but maybe that's just a result of the turbo slowing down the exhaust gasses and making a restriction in the flow, with no boost to compensate.
    • The boy just hit up google translate and it worked a treat, he said step one was "please urinate with precision and elegance", he then sent me the correct translation  I get some new loctite for the small fixtures tomorrow and get some "dort" going after that 🤣
    • Right, so is the fuel pressure the same as it was previously? If not, well, it's not going to work well. I can understand the theory I assume you are going for, which is: "Run it N/A, and if I have the original AFM, and same amount of fuel and intake air as previously, the fact there's a turbo in my exhaust should still make it run" Which it... might? Provided you don't actually change how much air or fuel is going into the car.. or getting out. But if you have changed that, all bets are off. What is the purpose to even have the car run this way? To get it to a tuner? And if the goal is to limp it to a tuner, you're still going to what - plumb up a whole intercooler system and new intake in the parking lot out front before your tune......?
    • Haha yea it's a bit of a weird setup at the moment, just wanted to make sure I sorted out any headaches before dyno day. At the moment I've changed the exhaust manifold, turbo and downpipe, 460lph fuel pump and rising rate reg as well as the previously mentioned headstuds and gasket. The nistune was already mapped for the car as it was and drove around for a few months no worries. The plan is to run flex fuel hence the big pump, which I've wired direct to the battery through a relay to avoid voltage issues.
    • Um. Was the ECU the same as the one previously there? I know R33's needed R32 GTST ECU's or other tomfoolery to run Nistune. This is such a wild setup. Most people would plumb in the turbo then not drive the car (i.e tow it to a tuner). What's actually changed since it last ran?
