HI Everyone
Warning this maybe a silly questions for some but im still learning about boost and turbos Thanks
i have a delema i have heard that on stock intercooler and stock turbo the most u can boost is 14psi and the setup goes bang bang bye bye. so my questions is if you get a bigger intercooler can you boost it up to 15-16 psi or is the turbo going to got bye bye or do u need a high flow turbo if you want 15-16 psi
any help is muchly appreciated sorry if i posted this in the wrong spot
Thanks :rofl:
https://www.sau.com.au/forums/topic/167257-when-turbos-go-bang/
the general rule, is max boost for stock turbo is 14psi; most people have found this is where the turbo makes its max power, so even if you turn up the boost doesnt mean you will make more turbo.
If you want to run more boost, then look at buying an aftermarket turbo or getting your stock turbo highflow
^^ was about to say the same thing.. PSI is just a measurement of the pressure in the manifold.. A high-flow running @ 14PSI will generate alot more air than a normal turbo running @ 14psi..
Also - as you've got a R33 Gts-t, advised boost on stock turbo is 10 - 12psi, any more and you risk shattering the ceramic exhaust wheel..
thanks for all the input i think i will get a intercooler and run the lower boost like link said. i dont want to spend big money on all this. if i do have a bigger cooler and run 8psi daily driver and 12 for race day will this work okay and not ruin anything to quick. i dont want to hear bang ssssss when some thing decides to die on its arse haha
thanks
OK as Links said, I would NOT advise going over 12psi, 14psi is too much, WHY? 33gtst have a ceramic wheel in the turbo, great for low spool due to how light it is however it cracks and shatters under heat.. NO a turbo timer will not resolve the issue. Its when its at full boost etc when it gets too hot and out the exhaust pipe it goes.
In summer I would not go anywhere over 10psi, i have been through enough turbos now to advise you of this.
mine still went at 11psi from standard wheels, so now have high flows, I am now on my third high flow and i recommend not taking high flows over 16psi... sure i can put it up to 22psi but it dont last long! a general highflow of the standard turbo i would not take over 16. remember 4psi from a high flowed turbo is more than 4 psi from a standard turbo.
I have generaly paid about $1000 for my highflows. I love highflows, still the same low spool due to the same housings etc and a nice bit of boost.
By the way shenron i saw you on the freeway tonight, i was in my 1979 laser at the time so not noticable.
Before you get intercooler I would do ecu or SAFC to get air fuel mixtures sorted PLUS a dump and down pipe from your standard turbo, i managed to putt 290rwhp off standard turbo which back in the day was quite good....until it blew :-(*
i would get the intercooler before I get an safc or ecu
lower intake temps , less heat and stress and far less restriction than the stock cooler . assuming you have a full 3 inch exhaust 1st .
free up these restrictions 1st before you try and add more power through boost/ecu
i have a 3inch dump pipe straight though to a canon and i have a pod and so fourth so then next mod was going to be the cooler but i will take this in to my budget to see what i can afford and go from there thanks for the advice.
was ur laser white i think i saw one laser surprising i didnt try race u haha there was a volvo and a prajero that want to run last night and a celica hahaha.
You got 290rwhp out of a standard turbo and ecu? What sorta mods did you run?
Sorry Jie should have explained myself better - Was running SAFC and ITC Combo so fuel and air plus ignition timing was looked after.
what else? dump down pipe... the cat went for a walk for a little while in the exhaust but she came back now, fuel pump, Blitz duel SBC air filter.... then the usual after that, cam gears advanced timing etc etc. It DID have and still has one of the most expensive coolers on the market (custom made by Micks Metalcraft) installed at the time my quote above though was based on the fact that the standard turbo with supporting mods can make nice power.
Ummm yeah the dyno was recorded on the Dyno dynamics at PSI so we may have a bit of a problem getting it off there. Both mine and gtstvspec managed to get that kind of power but paul had a nice greddy plenum attached to his.
Even at 12 psi the turbo blew...... maybe with Pauls plenum thats why his turbo didnt blow like mine... or did it?
I thought a nice turbo backe xhaust, fmic, safc and a boost controller would yeild 260-280rwhp normally in a gtst at approx 11-12psi on stock turbo
mmmm tempting to get back into a skyline lol
im running a series 1 rb25 on an rb20 (series 1 is mean to be smaller/weaker) and i have been running it at 18psi for the past 2 months and it has not had a single problem lol. It doesnt matter if it does blow because the engine and turbo are just temporary, but yeah just thought id add that in haha. Not a single problem so far.
    • To be fair passengers who aren't silly and have been in proper fast cars have often been pretty impressed once you hit 4th gear
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
