Can anybody tell me whats involved in converting the 25 hydraulic valvetrain to the 26 setup' Is it simply a matter of 26 lifters and shims or is there more involved?
You need to get a tomei (or other)kit, as the valve height of a 25 and 26 is completely different
Strange
The head that I have at the moment is a 25 that's been modified to run GTR cams, and the GTR valve stems etc went straight in.
Is this just because I'm running the right cam for those valves etc?
Strange
Cam's aren't tied to the valves. The valves are tied to the lifters though...
That's how a rb26 lifter is, notice how the valve goes pretty high into the lifter and the actual lifter is very short
Notice the length inside the lifter? that is how a rb25/rb20 lifter is set up. because of the length difference rb20/25 valves have that length difference taken off compared to rb26.
Edited by klh6686
The RB26 valves stems are much longer than the RB25 w/hydraulic lifters. The RB26 exhaust valves are even longer than the RB25 NEO exhaust valve stems, but the NEO intake valves are longer than the RB26's. In short, there's no easy way to go about converting to solid lifters with an OEM parts mix. A kit is your best bet.
    • I clean my wheels every time I wash the car, I also clean the barrels, the only product I use on the wheels is truck wash and a pressure washer, followed by (inset your chosen name brand) wash and wax, time per wheel is probably 2 minutes total, cleaning the barrels is easy with one of these microfibre thingies on a stick from Sabco, they're also great for getting in between the front guards and body, and tight spots in the engine bay ย
    • An updated post here. Sounds to me like there's definitely a bit of sketchiness here.ย  Old mate with 10 rusting Torana's in the front yard might be more who they're focussed on. (For right or wrong).
    • Is this not just about people wrecking, and storing, multiple cars in their front yard? I now a tow truck driver that was contracted by the council to clean up housing commission front and rear yards in houses and unit car parks I'm all for working on, and doing maintenance on your car in your garage or driveway, but some people definitely take the pissย  There's one house locally to me that I walk past regularly where the front yard and driveway looks like a wreckers, multiple cars in various stages of being stripped, and the yard looks like all of fluids are basically dumped on the ground I may be wrong, but it seems that the initial reports, which I've seen nothing actually official about yet, may be getting taken out of context, like alot of the latest "the sky is falling" stuff found on the youtubes for clicks
    • have they? Link appreciated. I live in Casey. I can see both sides of the argument in this case. There's a lot of sketchy stuff going on. There needs to be a clear definition of what this is supposed to be IMO. I wager the intent was to be a broad sweeping brush against people who have 4 cars up on blocks on their front lawn, not someone who services their own car behind their own gate on a weekend bothering probably nobody. But it'd be hard to legislate the difference there.
    • Oh, the wheels were already off. I wouldn't normally take them off to clean them although it does make it easier with the ceramic, so I might take them off when reapplying. I don't drive much but now with the ceramic coat, when I do drive and they get dirty I can get most off with the pressure washer. I'll be switching to dirtier pads soon which was the motivation for the ceramic as I usually just clean them and sometimes use Autoglym wheel protector. Nah, f**k the barrels! Haha, I'll give them a quick scrub when they're off the car and a pressure wash, but even I draw the line with the barrels. Yes, dark coloured wheels allow you to get away with a lot! ย
ร—
ร—
