actuator level controls when the wastegate opens on the turbochager
so fitting a 15psi spring in the actuator means it wont open the wastegate until it see's 15psi
this means you can't run less than 15psi and control it.
ie: you can't fit a boost controller and run 10psi with a 15psi actuator.
if you want to run more than 15psi you can then fit a controller to increase it past 15psi, but ideally you should run an actuator to closest boost setting you want.
ie: if you want to run 1.3bar then you should run a 1 bar actuator. dont run a 7psi actuator and run 1.6 bar as the controller has to work very hard to maintain stable control and keep the gate in control
