I'm currently building an RB25/30 for my 32, would a standard GTR plenum fit on an RB20 25 or 30? if so wouldn't that be the best bet with the multiple throttle bodies? or some thing simpler like a greddy?
i would also like to no if a gtr plenum could go straight onto a 25?? also the ebay "greddy" plenums they say they are a copy, good or bad idea
Seriously dont know why people bother with these cut and shut stock plenums. If you want a forward facing plenum then fair enough, so do I, but if your going to do it then do it properly and get something like a Greddy or Plazmaman plenum. These companies have spent lots of time and money trying to perfect the flow characteristic of their product and saved you all the hard work, so I think the extra money is well worth it.
Plus they look a shitload better than modified stock, plazmaman especially.
Here is my plenum... I'm not sure what it is as the previous owner just said it was 'custom'. It's using the standard throttle body.... my head gasket just blew the other night... not sure if this is related to the damages as im still trying to grasp a better understanding on mechanics.
Feck me, nice car to be "learning teh mechanics" theres some heat in that bay for sure
  • 2 months later...
yes gtr plenum can fit onto an rb25 head. Blitz makes a bolt-on adopter kit its worth about $700 and then you have to buy the gtr plenum and sort out the injectors . and blitz made a comment that it wont work with a std ecu
Do you or somebody else do know where i can get this Blitz adapter kit ? I would be very thankful if somebody could help me.
Edited by Behind Horizon
I would not like to use the std plenum just sealed at the center and a hole put for the inlet at the front because of obvious uneven distribution.
I built my plenum with care to try to avoid this problem but probably would have been better to buy Plasmaman/Subzero etc.
i'm just checking that you really think it has lowered intake temps by 30 degrees?
exactly how and where did you measure this?
ps. i have measured mine at the plenum so i have a pretty good idea why you won't lower intake temps by 30 degrees when you remove a little pipework.
well i guest you dont tune cars then sore the temp drop on my haltech,mates ems and motec all 10sec cars guest that proves that it works
hey bud i have used a cut standard one for the past 2 years without any problems and so have a some of my friends. your intake temps will drop by about 30 degress which = hp
When was the last time you tore down the motor to check for uneven wear to back up your claims?
    • Oh yeah forgot to also mention need to also unplug the IACV as well. Thanks for the reminder @MBS206 Unplugging the TPS takes it out of closed loop so you're able to screw down the IACV without the ECU trying to add/subtract timing to maintain the idle (not sure PowerFC can even do this, but Nistune and the OEM definitely does)
    • For sale is my 1999 Nissan Skyline R34 GT-T, tuned to 234 kW / 313 hp. I've had the car for a few years as my daily driver. The car is original (as far as Skylines go), with only a few minor upgrades to enhance performance and driving experience, as typical for such a car of its age. Overall, it is in great condition with no body rust, thanks to its earlier import date. It features a top-notch security system (not literally, but it's great!) with remote start and still functional 4-wheel steering via HICAS. It comes with several performance and handling upgrades, including:     Hypergear 450HP Turbocharger running 17 PSI boost, installed mid-2021 by Jaustech     550cc injectors     Nistune ECU     Front-Mount Return-Flow Intercooler     X-Force Stainless Steel Exhaust     Upgraded engine mounts     Bottom end bearings replaced     BC Coilovers     Lenso DR1 rims     Bridgestone Potenza Adrenalin RE003 TL 245/40R18 97W tires, fitted early 2023 The interior is mostly stock, with a few additions:     Viper Satellite Tracking System with remote start     Bluetooth Double-Din Touchscreen Head Unit     Steering wheel cover Cons:     A few paint imperfections here and there     Driver’s seat shows more wear than the others. It's not torn at all, but I've added a seat cover to protect its condition. I also have a CarVX Vehicle History report available for serious buyers, so you don’t need to purchase it yourself. Price: $26,000 ONO.
    • I've had two suzukis in the past have an extremely hard time turning over and not starting after sitting for a few weeks. Ended up the alternator would seize up causing the starter to force. Same issue both times.  Maybe they're sourcing their alternators from the same place...
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
