hey guys
selling this for a good friend of mine
i aint even guna talk this car up... anyone thats seen it knows its 1 of a kind
CLICKY FOR REXY!!
for lazy kents
Comments
This WRX is a real head turner inside and out, has full service history from Subaru up to120k and done every 7500k thereafter by Nismo Performance, full car maintaince service 1000k ago. Always looked after always garaged, well maintianed & Mature Owner Majority of Mileage is travelled on freeway.Never been in a collision and has never given me a problem the car is mechanically perfect and only the BEST parts has been used to service it.The car has:
--Factory Leather Trim with Momo Steering wheel.
--Exforce 3" Exhaust System from uppipe (before the turbo)to tip worth $1.5 all stainless steel,mandrel bent with hi-flow cats
--3 Mode electric Sunroof (closes automatically when shutoff)
--18" Sport Max Racing Multi-Stud Rims with Fedral Tyres 98% life 225/35 (worth 4k)
--Digital Fuel Adjuster lets you alter how rich or lean the car operates &
Digital Boost Controller which lets you switch between 2 boost maps (better then 2 boost levels)both controlled via Hand Controller & Switch
(Boost Maps 8psi low & 16psi high)
--AutoMeter Boost Gauge
--Greddy Turbo Timer with Voltage reader
--Custom K&N Intake System
--Cooling Pro Front Mount Bar & Plate Intercooler with mandrel bent pipes
--Drift adjustable atmospheric Blow Off Valve
--Top Gun Leads with NGK Iridium plugs
--Kenwood Head Deck with 4 Response Prisicion 6" splits with high-def crossovers and tweeters. Also 10" Pioneer 350w RMS Subwoofer powered by Response Prisicion Amp with 2 Farrad Capicitor
--Orbital Deep Cycle Battery ($460)
--Top of the ranger Viper Alarm System.
Even with all the performance parts the car still delivers fantastic everyday drivability and good mileage on low boost.
Serious buyers only please and all reasonable offers will be consider. $21700 ono
feel free to call "jayr" 0401586405 anytime after about 4 oclock for inspection etc
cheers
Edited by bLaQ.bOi
Guest
    • You see R34 GTRs listed for 200-300k are they really selling for these prices? Kinda seems like the same ones listed all the time.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
