Sauwa Wa?
JP80
 Share
i moved from Perth to the south west about 7 weeks ago
been pretty busy so far with my jobee and all, but i have been wondering recently:
is there many SAUWA members or even just SAU people down here?
i'm referring to the Dunsborough/Busselton/Bunbury regions and close surrounding
i'm guessing most of SAUWA is pretty Perth orientated...
i live in busso,i drive a black r33,you might of seen my car.
as in today as i was leaving the BP across from the cinema?
there are a few down southers about but they don't live on the forums like us perthians with nothing better to do :blink: You'll see me down there a little bit - my parents have a house in perth and one in Dalyellup in Bunno - so it makes for a cheap getaway :D
Gavin - its a friggin nice house too! its right across the road from the beach - two storey ..... nice n big. Might have to do a SAUWA south cruise one day like we've always been planning to do but never get around too. Cos it could comfortably house about 20 people.
All this extravagence and my parents are going tightass on my birthday *mumbles* :banana:
+1
Ahh don't feel lonely. :D
There are few of us down in the SW.
Just gets really tossy on weekends when the porshe, bmw and merc brigade invade from the north. Fill up all the good roads with all that high priced s.... Good for giving the local coppers a boost in out of town revenue though.
 Share
    • Hi there, after a quick google search I found this topic as I am also relocating the battery to the boot of my 1998 GTT. I was just wondering how you got on with installing the re-routing and specifically the installing of the harness protectors? How do they attach? Are they just a simple "click-in" affair, or do they attach with bolts? Does the GTT have all the necessary fixing holes for them, for example, where they locate on the chassis? Any help you can provide would greatly appreciated.
    • Thanks mate, yeah I've heard that alot and i am definitely regretting using the 25 Loom now, i have gone through and traced all the plugs from the 20loom and re wired them into the 25 loom, I have currently got Crank, Fuel and accessory's working, just need to finalise the loom and run the wire for the Ignition (Spark) and it should be running, will update if i have any luck.
    • Cheers lad, when I head over there I'll give it a shot.
    • Stock less likely to carry one like that than urethane, but still can, especially if the bolts are not as tight as they should be. If it's making that much noise you should be able to use a hose as a stethoscope> stick one end in your ear, crouch down and wave it around the various possible noise makers and get someone to lift the front end at the guard lip.
    • Broken actuator rod. Could be one of a couple of them broken. Or, it's locked and the central locking actuator is broken/stuck or the actuator rods between it, the lock and the key barrel are jammed or broken similarly. You'll probably need a locksmith/mechanic who is experienced with using slim tools to reach down next to the window glass to manipulate the mechanism. That's assuming that it is not so severely jammed/broken that nothing useful will move.
