Not really comparing it.. Just the front bar.. looks like something off a sonata.. I'm sure the engine is bigger..
hmm....Sonata?...someone is on drugs. I like the front bar on the car in your signature though, fully chromed and tough!...I'm sure the engine is even bigger..
  • Replies 64
Posted Images
top speed is clocked at 213 mph.
A close contact to the road is ensured by the typical and well sold Rinspeed 20 inch aluminum wheels in the C5/1 design. The rear wheels have been widened to the size of 12 x 20" especially for the Turbo. The tires sizes of 245/30 R20 at the front axle and 325/25 R20 at the rear axle hug the road for sufficient grip for the Swiss super sportsman.
340km/h top speed! Yum...would like to see the Z tune gets anywhere close to that. maybe 290km/h at best.
325 rear tyres on an AWD car! and I thought only the Dodge Viper needed those!
I gotta say, that is damn nice. One of the better kits on the 997 turbo. Looks as if your actually getting something for your money.
But best porsche colour is black. I see a brand new 997 every day that is black, and its definately better.
Start with the NEW GTR, give it to Mines to tune with a budget that gets your spend up to $250K, watch the Porsche in the rear view mirror.
Lets compare new to new. The stock new GTR is faster than a 911 Turbo (track result from testing in California). Much as I love R32/33/34s, time is passing and technology is improving.
I would take the Porsche over anything shy of a Z Tune. It might be faster than a Z tune but give there were only 20 made which do you think would be worth more as a collector. There's a lot of car faster than a Shelby Cobra but there's only one left of them....
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
