nissan skyline R34 GT-T white nismo edition 1998 5 speed manual turbo 6 cyl 2.5litre neo spec 2 door 5 seater AZT-24W
55,000 km, serviced every 5,000km have log book which serviced by bels garage reciepts all kept
recently bought 4 new tired bob jane with life time warranty
castor rods have been changed
hks super induction pod filter still with air scoop
aftermarket high volume grounding kit in engine bay
i have an apexi power f.c ecu with hand controller for this car and kept original ecu which will be supplied to buyer
orginal nismo areo kit this is the geniune kit not any after market kit
car hasnt been in any accident nrma inpection more than welcome
car has always been filled with v power 98 octane and been dyno at bel garage with power f.c and running 11psi with 175kw at the wheel have dyno papers
excedy heavy duty clutch natural
bendix ultimate brakes and have machined disc when replaced
i am the 2nd owner of this vechile in australia
nismo eyelids had been ordered from japan, have been sprayed with colour matching paint and fitted (glued)
greddy digital duel stage boost controller low is 7psi and high being 11psi
car is well maintain inside and out with no scratches or burn marks
car also has nismo clear side indicators and nismo fog lights
car is pretty much stock besides the boost controller and pod filter
rego till june
alpine stereo with 6 cd stacker in rear boot
cup holders
digital turbo timer with dual setting and other functions
window lifter set on alarm
mongoose 3 stage black wiring alarm
fatory tinted windows
nismo exshaust
dual air bags
12 inch clarion sub woofer inclosed in boot
700watt clarion amp
all power options
$26,500 ono
may swap, open to suggestion
contact 0406015982
https://www.sau.com.au/forums/topic/167350-4-sale-r34/
Just got a few extra questions bud.
Does the car come with factory air box, as this is needed to pass inspection for RTA?
Is the car running 11psi off factory intercooler or do you have a FMIC installed?
Could you put up a pic of the front from head on, and a couple from the sides please?
I take it you are in NSW too?
https://www.sau.com.au/forums/topic/167350-4-sale-r34/#findComment-3101189
    • You see R34 GTRs listed for 200-300k are they really selling for these prices? Kinda seems like the same ones listed all the time. Even with R33 GTSTs looking at gumtree. You have an auto with a bitsa interior for 35k. Another one needs an engine rebuild and asking 24k. And then you have a stock in better than average condition for 45k. Nobody is ever going to pay these prices.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
