I'm thinking about 'upgrading' my R32's RB20DE engine to a neo one which should give me some better fuel efficiency, cleaner emissions and _slightly_ more torque(186.33 N*m / 4400 rpm vs 184.37 N*m / 5200 rpm) . I'm having a hard time finding information about the engine and what differences there are with a non-neo engine. I'm wondering if i could get away with swapping just the head/loom/ecu and using my current block/internals or if its a lot more extensive than that (eg full engine transplant required).
If anyone could point me in the right direction that would be great.
And no RB25 or turbo is out of the question at this stage (damn you insurance company :) )
https://www.sau.com.au/forums/topic/167365-neo-engines/
RB20 neo would not be worth all the trouble. Wouldn't it be worth paying a little more for insurance and getting an RB25DE Neo?
https://www.sau.com.au/forums/topic/167365-neo-engines/#findComment-3096332
Like I said, rb25 isn't an option. As I am under 25, my insurance company will only allow me to insure a car 2 liters or under. My insurance company currently gives me very good rates as the rest of my family use them also. Then on top of that I would have to get a certification done (government requirement here in nz) if I used a larger engine - about $450. Believe me, I would love to plonk in a rb25 - but its just not viable atm.
Anyways, less whys - more how-tos :rant:
https://www.sau.com.au/forums/topic/167365-neo-engines/#findComment-3096806
do you know what 2 NM extra torque would feel like?
you could get better fuel efficiency by buying a $350 brand new Apex SAFC and leaning out the mixtures a bit. you'd even get better power and torque from that also.
And guess what, you wouldnt have to rip the motor out!
https://www.sau.com.au/forums/topic/167365-neo-engines/#findComment-3096917
You can see that it also peaks 800rpm earlier - which may be more noticeable and possibly improve the drive-ability (so gutless down low :P ). There is also quite a significant fuel consumption drop between neo and non-neo. Plus I enjoy taking things apart >_<
As for the SAFC, I'm planning on getting a second hand one already. I figured using it with the neo head should give some good benefits.
Thanks for your suggestion tho.
Edited by Sinturion
https://www.sau.com.au/forums/topic/167365-neo-engines/#findComment-3097295
so you wont a bigger n/a hey.
well nuthing beats displacement so why not go and get an RB30E and put a rb25de head on it. this should be good for around 130wrkw and plenty of tourqe. should be pritty simple to bolt in the rb30e block and then get the head wired up.
aslo witht he rb25/30 you will need to get the rb25de pistons to have the right comp ratio and if you deck the block i believe it is .74 thou you will have a 12:1 compratio.
this in my opinion would be the best path to travel and then if you wont to go turbo all you do is pop in some turbo pistons (get rb25det head if planing to do so) and wack on a tubro of u'r choice.
hope this helps brentt
https://www.sau.com.au/forums/topic/167365-neo-engines/#findComment-3098398
Mate in all honesty, considering your position my suggestion would be forget about modding the engine & concentrate on suspension mods. You'll learn a lot & by the time you hit 25 you can get the car you want & go nuts on it. HP isn't everything.....
https://www.sau.com.au/forums/topic/167365-neo-engines/#findComment-3100938
as above, you can get about 100 at the wheels out of them, and with a lean tune it should be pretty good on fuel, then go suspension etc
that said, they dont have to know you have a 25de in it, you can even go as far as changing what the block says (to your current 20 engine's details) if you want to be dodgy... never be the wiser
other than that, its a 20 give it some cams a good tune, timing compression, flow in and out, and then just let it rev, should be fun enough for now
https://www.sau.com.au/forums/topic/167365-neo-engines/#findComment-3101273
Hehe
While I appreciate the advice - I would really like to know what the physical differences between the rb20de and rb20de neo are. I think the rb20 neo is more common in NZ than in AU. One of the main factors for doing this is also the learning behind it, so that when I build my rb30de I have a clue what I'm doing.
Btw, just brought a secondhand SAFC2 - going to pick it up in a minute or two :P
https://www.sau.com.au/forums/topic/167365-neo-engines/#findComment-3104229
I've been reading the R34 engine manual. Apparently the RB20DE Neo has variable valve timing control, as well as variable air intake control - both which claim to increase torque at the lower and middle ranges. It also has 'air swirl jet control' which has something to do with making combustion more stable. More reading required!
https://www.sau.com.au/forums/topic/167365-neo-engines/#findComment-3111812
If I was doing this, I would do the 2.4 stroker conversion. That would give you the torque increase you want, and there is no way the insurance company are ever going to know.
I would also fit a power FC, and then get the car properly dyno tuned. The whole thing should then run pretty well, and the engine still looks completely standard and original.
https://www.sau.com.au/forums/topic/167365-neo-engines/#findComment-3112169
I was reading about the rb23/24 last night conversions last night. Seems like there might be some expensive machining work involved to bore it out to 81/82mm?
I can't find alot of info about an NA rb23/24 - just the turbo ones. What kind of effects will it have on the compression ratio if i used 4age pistons and a RB25 (or RB26) crank?
https://www.sau.com.au/forums/topic/167365-neo-engines/#findComment-3112190
    • Yeah, you are right. It seems easier and more reasonable to boost the engine. And as you said the blocks are very similar but the cylinder bores are different.
    • Sound logic, but in actuality way more illegal than just having the wrong pipe. Normally, doing something like that would be forgery. Meaning you may have certain documentation for vehicle parts, but the actual parts are different ones and you just assign them the numbers and badging from the documents. But nevermind that. Nonetheless, I AM curious if this pipe was ever made by any official manufacturer this way, because I honestly am not familiar with this pipe layout and shape. As I will be putting on the HKS Silent Hi Power once my exhaust gaskets arrive, as long as it sounds right I will just roll with this front pipe. I can always order the actual Mines part if I run into legal issues. It would be an unnecessary expense as there is lots of other problems I have on this car as of now.
    • So, weld a plate with the Mines logo laser cut into it, onto it. Instant Mines pipes, whether they were or weren't originally.
    • I don't know if the blocks are "the same". They will be very very similar. Obviously, either the bore or the stroke is going to be bigger on the 20. If the bore is bigger, then the 18 head is unlikely to fit properly. If the bore is the same, then you can almost certainly fit the CA18 head, but there migth be a few fun things you have to do to make water galleries (or other things) line up properly. Or... it could just be real easy. Is it worth the effort? Almost certainly not. You can make nearly as much power on a 2 valv ehead as you can on a 4 valve. There's not any "magic" in a 4 valve head.
    • Yes, me too!!!!  I need to find a something that has all the abbreviations for what these cars have LOL
