$28 gets you 5 items, can get multiple permit sheets.....
they shouldnt be giving anyone permits for exhausts, if you got one your a lucky man, theres a ridiculous amount of inconsistency within the perth pits regarding inspecting and permitting
https://www.sau.com.au/forums/topic/16741-permits-for-mods/#findComment-344164
WTF !!
I got permits for everything CEPT zorst.
Had my zorst tested and it was below limit. But the guy said we dont permit exhausts. This was east perth pits.
Damn its annoying how inconsistant this crap is !!!
Which pits you got to Metblue ??
https://www.sau.com.au/forums/topic/16741-permits-for-mods/#findComment-344276
It's the DB that makes the Zorst illegal.
Cop measured mine. Said they dont permit them FULL STOP.
Too easy for you to go round corner and change it. Even though that goes for everything on your car :|
As Mayhem said, loop hole so they always got something to sticker you for.
https://www.sau.com.au/forums/topic/16741-permits-for-mods/#findComment-345219
Well guys i can tell you that I HAVE got a permit for my exhaust, he didn't test it, just listened to it and allowed it... I have a Blitz BOV which vents to atmo and i have a permit for that...
I think i can scan in my permit for the non-believers...
Butters: I got mine through Welshpool pits...
https://www.sau.com.au/forums/topic/16741-permits-for-mods/#findComment-345600
I think we believe you dude..... its an example of the inconsistency and flexability of the DOT and interperataions of ADRs
I wouldnt scan it, Id laminate it and make sure its safe.
as for bovs how is it you can vent crank case gas atmo through a bov but need to recirculate it to burn it? I got teh ADRs on CD coming
Who is We vspec? do you suffer from psychitsophrenia?
https://www.sau.com.au/forums/topic/16741-permits-for-mods/#findComment-345649
Mayhem is right.
BOV's are technically illegal by the laws of emissions. Once Air has entered the engine via filter, legally(emissions laws) the only way it can leave is through the exhaust.
If you got a permit for one, or have been told they are legal then it is the "inDUHviduals" interpretation.
We beleive you Met-Blue. Just want some of this permit goodness for ourselves :) hehehehe
I am out to Welshpool soon I thinx. Can you tell me which guy you spoke to ??
https://www.sau.com.au/forums/topic/16741-permits-for-mods/#findComment-345669
Butters and Mr Mayhem - all laws are up for interpretation.. Reno who is effectively the godfather of the pits and inspections for WA (so I'm led to believe) says that BOV's are legal as long as they are not too loud. Same goes for exhausts and the like. Basically he was saying that they had flexibility and as long as you hadn't done anything overly stupid you could get a permit for it.
Paul isn't crazy - he meant we as in a group of us that went to the info session.
Apparently cause I'm an engineer I can sign off on design mods. I'm sure I can find evidence somewhere to say that carbon fibre bonnets are ok.. :D
https://www.sau.com.au/forums/topic/16741-permits-for-mods/#findComment-345706
    • Not R7R. Meant to type R&R, obviously enough.
    • Bugger "making it look stock". I put one conventional internally fused Hella relay behind each globe. I just pulled the plugs off the back of the globes and built new loom segments with male and female plug parts to match up to the original loom and the globe, and used the original power wires to each globe coming from the switch through the original loom plug to trigger the relays. Ran a big fat (also separately fused) power wire across the front of the car to feed all the relays. It's as ugly as f**k, but it is wedged down between the headlight and battery on the RHS and the airbox and headlight on the LHS, and no-one ever looks in my engine bay, and on the odd occasion that they do I simply give no f**ks for what they think. Fully reversible - not that you'd ever want to. For f**k's sake. It's a Skyline. They made million of the bloody things. We've been crashing them into roadside furniture for 30 years now. There is a negative side effect to putting relays on the headlights. The coil current is too little to properly clean the contacts in the switches and they get blacked up and you have to open them up every couple of years and clean them manually. I have 25 years of experience on this point.
    • I was poking through the R34 wiring diagrams vs R33 and noticed that the R34 has proper headlight relays while the R33 is like the R32 and sends full headlight power through the headlight switch. I'm not afraid of wiring but I really would like to do this in a way that looks OEM (clipping into open positions on the OEM relay box) and also unlike the factory wiring which interlocks the high beam and low beam on the halogen series 1 GTR headlights I want to make it such that turning on the high beams keeps the low beams on as well. Any advice on how to locate the specific connectors + crimp terminals + relays I need? I was thinking one NO relay for low beams and another for combined high + low running off the factory high beam headlight connector. I don't really want to splice into a crusty old probably discontinued factory harness so fully reversible is my goal here.
    • Pretty sure they run the same engine as the Q50 hybrid which specifies 95 RON.  I ran 98 in mine for a while, but it made no difference in performance or economy, so I have been using 95 for the last few years.  I have never hit 6.0L/100km, but have returned mid to high 6 on the highway.  Being a hybrid, fuel economy is a lot more dependant on how you drive it.  At 110km/h, mine never goes into EV mode on the highway, so returns closer to 7.5L/100. urban driving can return low 8s if you are careful or over 10 if you are a bit more enthusiastic on the throttle.
    • About a quarter of what you want to do. It's only R7R, not R&dismantle&replaceparts&reassemble&R. ? It is stock. I already told you, you will NOT have broken those. It's f**king 4th gear for Christ's sake. You just chipped the teeth off.
