Im thinking about selling my jzx90 it isnt running it was an auto turbo diesel, blown head gasket motor half pulled out to make way for 1jz conversion as is not difficult especially when using jzx90 frontcut, car is complied and has been registered in sa before,has full set of HSD coilovers has some damage on passanger side but nothing too major. no pics as yet but i can get appon request.
looking for around $5000 ono pm me or call 0407788542
Edited by kymtec
https://www.sau.com.au/forums/topic/167421-jzx90/
