http://www.zlx.com/corvette/turbo.htm
Manufacturer's Test Ratings
0-60 mph: 4.4 sec.
0-100: 10.5 sec.
1/4 mile: 12.9 sec. @ 111 mph
Top speed: 191 mph
Fuel Economy EPA city driving: 14 mpg
EPA highway driving: 25 mpg
C/D observed fuel economy: 17 mpg
the calloway twin turbo set up on the corvettes..
im in love..
any body had the luck of having a spin in one of these??
apartenly
any corvette 1991 downwards as long as its not the LT1 motor can be turbo charged with out an issues
and with a 12.9 sec run @ 111mph
that would be some serious fun
https://www.sau.com.au/forums/topic/16744-this-is-some-bad-arse-power/
american's luv their vettes thats for sure..and so many power upgrades. Imagine how quick it would spool up to with the big block..
I used to like them, but seeing some of the older ones on the road these days and even sat in one at a dealer.. not really that impressed. They look pretty old and dated.
A new one of course would be a total different story.
The Z06 will continue to be outfitted with the unique six-speed manual transmission for 2002. It will enable skilled drivers to achieve 0-60 mph times of 3.9 seconds and to cover a quarter mile in 12.4 seconds at 116 mph.
nasty...almost makes a GTR look slow!
thats fair enough i guess u can make any car go fast with 10 grand worth of mod's
but the fact is
most of the 7sec cars even the top fuelers
they r all big block 8s if not big block they r 350s.. u never see much 5 sec 2.6L
at the end of the day
no matter how much boost u run..
its cubic inchs that will get u the power if ur after a FULLY SICKKKK ANIMAL ahhaha
Guest INASNT
but the fact is
those engines r only good for full throttle and in a straight line.
has no relevance to a street car
zdenko,
is the 91 vette a C4? my old man has an 86 C4 which i think is the same shape and engine and everything as the 91. Goes VERY hard and looks the goods i don't care what anyone says!
Check out the ZR-1 corvette which was a 91-only model that is suped up from the factory and is a bloody beast over the normal vettes (which are beasts anyway!).
Ive sat in a C5 vette and of course my dad's and i prefer the C4 shape and the interior.
thought this seemed relevant...
Waz.
yeh
i love the c4
only problem being it doesnt have the power over da c5 which have the LT1 motors in em
bad point of those motors
compresion to high
to much hassel turboing em
so the c4 looks like the way to go..
i love them
allways been a dream car of mine
i loveee emmm
hahah
is ur dads manual or auto?
what do they do on the 1/4 mile?? any ideaS?
dad's is auto and stock 0-100 is 5.6sec
but he got a chip for $350 when he went to america last year! don;t know quarter but i would expect high 13s or low 14s
do u know of the ZR-1 vette? check this out before you buy anything coz its probably as quick at the TT one...
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
