I'm certain i saw this advertised on here privately a while ago but for the life of me I can not find the original thread or any information on this car. it was sold to a dealer which sold it to http://www.autowholesale.com.au/
http://www.carsales.com.au/pls/carsales/...amp;model_id=73
and yes i realise they are asking an amazingly ridiculous price.
looking for any info
Im not entirely sure if it came from japan to WA, or elsewhere in aus first, i think it may have been an eastern state car before comming to WA, nathan/gt51r if he reads this might be able to clarify..
its a genuine veilside produced car tho, think there was 20 of them made, that add claims ten tho, i recall it being more, initially had a t78 on it, was swapped for the t88 and a tune was done at the time by aj at speedworks <no longer works there> not sure if its been tuned again since then, but is highly possible..
it swapped hands from nathan to someone else, who then sold it to autowhole sale, i think, last time i saw it, it was at c-red getting a new clutch...
the price take is a bit silly, i seem to think it went for a lot less than that..
be a nice unique buy, but not for those bucks, given that im pretty sure the motor is internally standard...
A guy i know (Vince) owned this car for a while before swapping it for a mustang.
If your chasing some history, i see him most weeks.
This has been spoken about here before when it hade the number plate 600HP.
Search maybe?
Wasn't this originally brought in by UPI? I remembered seeing it at Dean's shop with the plates BNR32 in Vic. I heard that this car went to WA and exchanged hands quite a few times.
Search maybe?
If i remember right it was for sale at All America for abit,
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
    • Was that Australia Delivered Duncan? Does it have siren etc?   I used to have remote start on an old 32 two decades ago, it was a cool feature. I used to wake up early in winter for work. Start it and by the time i was out the door a few minutes later the engine was warmed up and the heaters had the car toasty. It was great.    I don’t mine the ambience lighting.  I drive a western star and it has footwell lights and ambient lighting and it’s great! From the pics of seen of them installed in a skyline I think it’s a nice touch
