Hey guys ..
Just put a new pod on my car, Seems to be getting more air (sounds like the filter is going to suck itself in) but a feel like its less powerful .. For the people reading its an Apexi Power intake..
The only real way to tell is to put the box back on but im to lazy to do that..
Can someone tell me im imagining it or its for real?
Also I need to link a cold air intake to the pod .. with the stock bar its pretty much impossable .. any idea on a way to get some hosing in there?
Currently using the stock intake funnel from the air box (im running no CAI presently) CAI will go on soon though .. just looking for a alternative to stock feed (im imaging its restricting air flow? fill me in tho!)
Edited by DECIM8
https://www.sau.com.au/forums/topic/167448-gtt-with-less-power-with-pod/
Well I can feel the power loss when I wack my silencer in! But from what ive heard thats about 20kws .. rumour ..
Maybe im just crazy hey?! Maybe in not dragging the gears out enough. ill give it a thrash tonight on the freeway ..
thanks for raising a good point .. seems im losing it
Edited by DECIM8
It came with an airbox for a reason.
Does it idle a little rough? Got heat-soak? CAI will help, but a box around the pod with feed/s will be optimum if you want to keep the pod. I'm assuming you only use the pod because it sounds tuff? Otherwise, just get a high-flow panel.
Well I put my cai on and yes it works alot better I noticed on longer drives to work the heat soak would kill the power and dumping it in second felt like dumping it in 3rd.. not kewl
CAI on and induction is actually louder but im using the stock feed from the original air box .. seems to work well and cant see a reason to do a direct feed.. when I get a new kit ill direct feed to the "GTR look like gap" that will be formed and meshed which should increase flow conciderably.
cheers for the help
Shouldnt you reset your ECU when a pod is placed on? As you have changed the air volume being sucked into the car, the ecu needs to reprogram it self for the more air.
Try resetting your ecu, by disconnecting battery.
Hope that helps
well mate ur definetely sucking in hot air from the engine...
id definetely recommend puttin in a box for it
as for the air ducting, if u have put in a front mount intercooler then u would have a hole from the standard side mount for the hose
You're imagining it.
I dont think he's imagining it. His just sucking in hot air from the engine bay which is creating heat soaking hence lower power!!! nothing beats the stock air box!!! you want some induction sound get a fmic.
Hahaa i got an apexi in the 34... and mann it sounds and feels great
I think the best way to fix this heat soak prob is to box it up and have the stock feed still there going into the box... but i wish there was another way of getting another intake pipe to come from under the pod but there aint much space is there? any ideas? pics?
    • fkin reckon, pretty sure it has head studs and a steel wheel in the turb I'll likely do a practice /shakedown day at Wakie before I call it ready to sell, then the new owner can have the first chance to put it in the trees properly
    • Congratulations for tomorrow mate! Retirement is definitely a milestone worth celebrating!
    • Budget for sensors and wiring as well. Depending on how safe you want to be with the engine, you could be flirting with $2K AUD in sensors and wiring.
    • Back on topic for you for a post Will it be on pump or ethanol? 2025 Spec RB build: G30 660 .83 would be good  artec manifold turbosmart 45mm external gate 1000cc Injectors Kelford cams 264 and springs Pistons and rods for insurance Oil pump with billet gears Headdrain and all good oil mods Quality intercooler 3.5 inch dump pipe to decent exhaust Link plugin Ecu or what ever your tuning is comforatble with Bolt on Trigger Kit - Nzwiring kit is go to ARP Headstuds Quality headgasket quality fuel pump- a TI/walbro 525lph PWM would be the go Quality fuel reg Will be over $15K AUD Enjoy the noise of rb on gate at over 7400rpm. Start looking for gearbox conversions if your hard on the gear. Now I've been there and done that with rb powered street car (2007-2022) much prefer newer stuff. Anything 90's Japanese is not a great experience these days and highly over rated. My 2015 Brz with a heap of suspension mods is such a better car even with out the power of my old s chassis' even on track. If wanting to play light chassis and decent power for a  giggle a k swap 86/brz would be the go Check my old build for engine stuff I really need to pay attention to post 2016 BMW stuff but seem all very heavy 1600+kg
