I have a 1996 R33 Series 2 GTS-T with fmic, full exhast, k&n pod, turbosmart bov, manual boost controller approx 10psi, also run on 98 octane which was running great until I got in it tonight and revved it to 1grand before releasing my clutch as normal and my car immediately started pinging loudly. It sounds like two metal objects banging together and doesn't stop until idling.
Before I continue, my car does suffers from a minor stalling issue where the car drops rev's dramatically when I put my clutch in and either dies or bounces back off 0rpm.... (this is only approx once a week, not a very frequent occurrence, I drive my car approx 75kms a day). My car also has a very low idle approx 600rpm.
I have already put octane booster in the fuel in case I had accidentally put in regular fuel however this did not make a difference.
I have left my car for 5 hours in a garage (so not exposed to the rain as I has been raining all day) thinking that possibly the pod or anything had gotten wet and caused it??? Hoping the best I start my car up and it immediately started pinning just above idle.
That is the story so far, it has had some changes (noises are different and responding differently) but I need someone please who lives south of the river (or north of the river if you don't mind driving) to please come and have a look at it and hear it. I live in Beeliar and most definitely would appreciate it if someone could diagnose the problem without me having to take it to a mechanic!!!!
Please help me I am really stumped!!!!
-jess
https://www.sau.com.au/forums/topic/167525-know-the-rb25det-really-well/
How loud is the pinging? Does it rise with the revs? Is there smoke out the exhaust (if so what colour)?
It could actually be metal on metal if you've done something major. If you leave the car in neutral or have the clutch in and rev it does it still make the noise?
Is there anywhere under the bonnet that its coming from?
I'm guessing it sounds like it's coming from the engine, but could it be the clutch? It's part of the problems you describe.
Its most definitely coming from the engine.
No smoke coming out of the exhaust.
Its not the oil
It does rise with the revs
It was really bad last night, still there today but not as bad, appears main banging noise is only slightly still there however there are still a lot of unusual sounds coming from my engine.
I'm thinking it might be sensors playing up as it is so random and has come out of no where???
It makes the noise in neutral and when driving, higher revs faster the 'noise' becomes.
I don't think its pinging anymore, however still sounds very rattly and like I said its making lots of usual noises and the exhaust now has a deeper 'grunt' / 'note' to it which wasn't there before.
I really can't explain much more then that as its too difficult to explain.
Really need someone to come have a look at it!
maby take it somewhere so someone can have a look at it?
I can't drive it, well i can, it starts fine, it drives fine but you can hear it.....
I think I will just have to take it somewhere.... I'm really worried I'm going to do it more damage by driving it though, I jumped in it a minute ago to take it on a short drive cos its running better today then it was yesterday and driving up the street I could hear it coming from the engine but my partner could also hear it coming from the exhaust....... does that cut down the ideas of what could be causing it???
In neutral its barely making a noise anymore, it still is making a noise but no where near as bad as last night or this morning, but the second I put it in gear becomes loud, through first its not too bad, the second I put it in second or third its way too loud and I think this is it still pinging?????
Really have no idea!!!!!!!!!!!
Any ides would be really appreciated as I can do lots of different tests here before I resort on taking it to a mechanic!!!
I've already got a AFC Neo and I'm waiting to book it in to get it tuned at 12psi but its not safe to do this until the car is no longer making this noise?!
I think it's no longer pinging.... I believe the noise I can now here is something else coming from the engine. I am thinking whatever had caused my car to ping was water in the engine or petrol tank?!
There is still a very violent noise coming from my engine and when driving my vehicle you can hear the noise coming out of the exhaust as well????
I am going to put meth in my petrol tank tonight to absorb any water that could possibly be in my petrol tank... I am also going to clean my injectors....
My car drives fine, my car starts fine, everything else sounds normal its just this one noise!!!!!!!!! (I believe I might have been driving my car for a couple of days whilst it was making this noise at the start of last week! It hasn't made any damage yet but just to be sure I will get a mechanic to have a look over once I have solved this!)
I am determined to solve this problem before resorting to taking it to a mechanic! I'm being quite stubborn!!
Might be worth considering that a coil pack has come off or something and you are missing on a cylinder. Try jiggling making sure that all tje cable you can get ure hands on are nice and secure. Apart from that id go for the obvious "something is seriously broken" option but if you say you werent caining when/recently before it happened its not as likely.
Found out what the problem is............ Need to replace my exhaust manifold gasket.... don't ask me how it was causing all of those problems especially the pinging but thats the only thing wrong with my car!!!!!
Thanks for everyone's help!!!!!
P.S Now I have to buy one, where do I buy a manifold gasket from???
Edited by jessr33
Should nt be hard to get one from your local repco/supercheap as long as you have stock exhaust flange. If not you could always get some gasket gunge and some gasket paper/mesh and cut it to fit.
Yeah we shall be finding out tonight on whether its the 'only' problem with my car but how the guy explained it, it made sense!
Can't wait to have her running properly again!
genuine nissan part so at least I know its the real deal!!!
Cheers guys!!!!!!
Edited by jessr33
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
