Just adding some parts (One car is still half complete and rolling)
*Gtr fuel tank $150
*Aftermarket mirrors available again $100 (one mirror is missing the glass)
*R32 RHS headlight $60
*Still have 3 doors available.
*Reverse, tail lights & no. plate lights available.
*1x rear cradels
Will post small items interstate
PM with any Q's or email [email protected]
Located in greensborough, Melbourne 30mins N.E. the city
Mob 0417 125 253 Elliot, PLZ CALL AFTER 4pm During week days as i can't answer calls during work, Any time wkd's.
Edited by KLR32
https://www.sau.com.au/forums/topic/167527-r32-gtr-parts-melb/
  • 3 weeks later...
  • 1 month later...
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
