Hey guys im new to the forum and em looking at getting this car
http://www.carsales.com.au/used-cars/deale...matchallpartial
Anyway its a non turbo 1996 R33 GTS.. and the seller is Power RD.Car Sales in Vic does anyone no of this place or heard of anything.. Im really keen on getting this car any advice on its price or the seller whatever would be much appericated thanks!
https://www.sau.com.au/forums/topic/167534-looking-at-car-wanting-some-advice/
The guy who sells cars there is actually allright bloke. He let me drive a car with my mate, he also does not force or push his cars on to you. He had some good and average cars when I looked... so when you go make sure you take someone who knows their cars. But yeah Id recommend buying from there!
The car listed also looks mint however you can get a turbo for about 2-3 K more...
when i was looking at supras, i was warned not to go there - kept wondering why, the cars looked pretty good - then it dawned on me, i was warned because the dealership i was talking to wanted me to buy a car from them! dodgey buggers
car looks mint - however, as said before, you can get a turbo for just a bit extra...
Very expensive for a non turbo. You could get a series II turbo for $2-$3k more. But if you're a P plater, then I guess you just have to go non turbo. Non turbo R33's can range from $8-$14k. You shouldn't have to pay more than $11k for a good example. Good luck :pwned:
    • How's your first born doing? 😛 As for now what? Time to forget about it for 12 to 18 months while your go down a totally unrelated rabbit hole... 😛
    • Fuse taps are perfectly fine to use, especially when you're adding stuff for your own car, and so long as you're being smart about it. IE, don't throw a 30amp circuit, onto a circuit that is only a small circuit. It's best to add a small circuit, to one that is already quite large. Oh, and make sure you're not going to blow the fuses that are further upstream too! I dislike their use in other applications, such as alarms, telematics/tracking devices etc, as it's far too easy for someone to unplug them and render a system useless. Those sorts of devices I go for wiring in quite secretively.
    • Fob is all cleaned up and it’s working well!! The amount of Vegemite looking sh*t that was in there is mind blowing
    • Given it is temporary, I bought a  cheapy gauge mount (which has become enflattened) which I will screw into the existing phone mount Also a first for me; given this is a temporary install I could not think of any reason not to use one of those "add a fuse" thingies to source the battery and IGN power. I had always figured they were pretty dodgy but having a good look at them I think they are a valid option for sourcing power from an existing source without cutting
    • Finally for now, a bit more work on the transmission temp gauge. I was wondering how Raceworks do a gauge for $100 that autometer want $500 for. No idea about the accuracy of course, but they have cut a few corners that made things hard.  First one I mentioned above, the sender is physically difficult to fit and doesn't work with their own adapters (the extra fittings I used to get the sender into a hose cost more than the whole gauge, lucky I had stuff in the shed) Second, the temp sender wires are way too short. They are shown as 2.7m on the box and I know my routing was long from navigator headlight to driver's firewall back to centre console, but I had to lengthen them by about 2m total - 2 joins in each wire. Also, same with the supplied power loom, they needed about an extra 1m to get the fuse box where I sourced power. Another join in each wire since one end wasn't supplied terminated. I know they could argue that the wires might be long enough depending on situation, but when you consider parts and particularly labour, it would be a very expensive cheap gauge if you can't do the work yourself. And, only a small issue....but it would have been nice if they remembered to tap a tread onto *both* spacers they supplied for the bracket....I haven't had to use the M4 tap often!
