-Location, Labrador
Hey just wondering if someone could point me in the way or be willing to come and fix my PC for me, im willing to pay but dont agree with the $90 p/hour most mobile PC companies charge, i dont wanna format my Hard Drive coz i got alot of personal material on there. i cant backup coz it crashes after 10 mins and runs like an absolute pig. I can pay you in cash, alcohol or foodstamps.
Thanks
https://www.sau.com.au/forums/topic/167542-help-with-pc-gold-coast/
how about give us some details?
if its crashing after a short period, its most likely heat related
take the side of hte case off and point a pedestal fan in there and see if that helps
unplug everything, take everything appart and clean it
make sure all your fans are spinning
so many easy things you can do yourself . . . .
im not really fussed if its a professional job or someone who knows there stuff as long as its fixed i spose. The problems i see is it comes up with a warning saying windows has recovered from a serious error. i click ok then it comes up again and again and again until its says windows has to close in 1:00. i have 2 viruses on it from other morons using my PC aswell. Thanks for the help so far
i know a enough to get me by and tried alot of different things but same result. Yeah i gove virus scanner but as i said some moron was using my PC and semi farked it not knowing what they were doing. it was working ok but downloading adobe for flight details it clapped out. thanks for the help peoples, ill use the recomended thanks
I can do it for you but im in SE brisbane underwood, all good software at your disposal helps, I say software problem, Either being viruses or spyware/Adware, First step is usually go into safe mode, Goto run and then type"msconfig" then goto startup tab and untick the items that you dont know about, usually able to distinguish whats what it doesnt take a genius, then move to the services tab down the bottom click hide all microsoft services and then usually untick the services that are present in there that are unknown to you. Then click applie and ok.
Restart then go back into normal operation, If you know torrents get adaware professional from torrentspy.com, install that then get the latest updates for the defs file, After installed run ad-watch then run adaware and do full system scan, clean the hell computer up a tad, Best done with disabled network. once that is done you may be right. Then again most people still have the "System Restore" Function still enabled so you could always restore back to a previous date. Bloody n00bs on computers i tell ya. Also easiest way to avoid these things is dont look at those "Naughty" sites and crack sites and serialz sites then you would be fine. Plus theres other tools like reghack that can help as well and alot of other tools, just check www.9down.com, it will be your friend for life with torrentspy, isohunt, and vcdquality and all sorts.
Oooops forgot one crucial point here, clear your cache your cookies your history, then gointo documents and settings your profile local settings and the temp folder delete everything out of that bloody temp folder thats where most problems lie
Hope that helps
Adam
lol i guess i can come and help you when im at uni one day.. for starters, your being hit by an RPC exploit (the windows shutting down thing).. which means you arent running SP2..
add me to msn and ill see if i can pop round sometime soon.
gervase AT allegro[REMOVETHIS] DOT com DOT au (paranoid about getting on spam list :))
or goto control panel administrative tools, then goto services sort by name locate RPC "Remote Procedure call" and one at a time for the locator first screen select manual in start up type, then in recovery tab select for all the failure tabs take no action, and for the RPC (blank) leave start up type alone goto recovery tab and same thing for the failures and apply and ok, then goto http://www.autopatcher.com/downloads/ then download your relevant updates, Thankyou :D
Thanks for all the help peoples, good feedback and recomended shops to fix my problem have helped heaps. i might have a fark around with my PC today with the new info i got and go from there. and no more german shizzer porn for me. haha
Thanks again
Adam
You can do the suggestions above and it MAY fix it, but I worked in IT for years fixing the darn things and they are never 100%.
My professional opinion is to organise all you personal files, photos, etc and back them up to DVD or another hard drive.
Then format the hard drive with a Windows re-install.
Sure you have to load up all the software again and it takes time, but most of the software may be outdated or irrelevant now, but you'll be better off for it.
It's cheaper than paying for a tech at $70+ p/hr too.
    • He's right ~ there is no 'magic' with stuff like this ... it is more likely that in the process of looking for the short, the loom/wire 'incidentally' got moved in the process, thus removing the short ~ now, that maybe a wire (in a loom) rubbing against the edge of some grounded metal, that's worn through the insulation, causing the (now intermittent) short to ground. If one wire in a loom has been damaged in this fashion, it's reasonable to presume that other wires beside it may have also be damaged, and now exposed...you can bet the green crusty copper corrosion will start... ...that'd be a pisser, Murphy's Law steps right in as GTS observes...but worse, something like that is easier to find when shorted...ie; unplug bulb and fuse, and put multimeter in continuity mode so you get constant beep, and carefully poke about hoping to find if some movemet of the harness stop the beeping.... ...it's still all a bit Arnie tho' ..It'll be back... 😃
    • Yeah, but knowledge of one wire's insulation worn through to short on earth implies the possibility of other wires doing the same. I had my power steering die, because the wire that runs to the solenoid valve on the rack runs in the same loom as the power wire for the O2 sensor. And when the O2 sensor/wire did something stupid and burnt part of that loom to death, the only indication was the shit(ter) fuel economy and the heavy steering. It took deep excavation of the looms in the bay to find the problem. Not wear through in that case, but similar shit.
    • Ah, I thought he'd wired it to one of the spare ECU inputs! Too long ago since I read that post, ha ha. I've been arguing with radiators, harmonic balancers, alternators and rust since reading it.
    • Correct. The ECU cannot read oil temp. (Well, I think it probably can in some situations. I did have the thought of potentially repinning the ECU when I was doing oil pressure). I am using this into the MPVI dongle, so that the MPVI dongle can read oil temperature. It is attached to a VDO gauge which is obviously calibrated to whatever curve the sender actually is using. This would be easy if I could setup a table of voltage to temperature like many sensors, but it appears I cannot do this and can only setup the transform rule which appears to be Input (voltage) x Multiplier, and add an offset. This to me means it MUST be linear. So it may be a complete waste of time wiring this into the ECU. The idea was that the MPVI3 has standalone logging. I wanted to use this instead of a laptop with serial cable (for wideband) for long datalogs. Given the wideband also has electric interference, I may never trust this either in a world where the serial wideband and the analog output wideband do not agree. Last time I did a trace I could see the two wideband traces follow each other, but one was a little leaner than the other. I plan on playing with voltage offsets and actually driving the thing to see how close they correlate. If they never correlate... then, well, maybe I'll never use either. Ideally I'd like to have the Analog wideband read ever so slightly leaner than the serial one, because the serial one is 'correct'. Tuning the car to be ever so slightly too-rich would be the aim. Not needing to have a laptop flying around in the footwell connected with cables is... an advantage. About the only one from the forced upgrade to MPVI3.
    • Hopefully not, since he knows the fuses work ha ha ha
