Hey Guys,
I brought this car 12 months ago and have just gotten it back from having my engine built etc. However, since i started i've had a baby and all the the money i've spent on the car has left me kinda broke, so sadly i have no option but to sell the car and move on. The engine is brand spanking new having driven less than 150klms. So the new owner will have to run it in etc. If it doesnt sell before i run up 1500k's i will have it tuned and post up a dyno figure. It really is a sad day, but i just gotta do it. Details go like this...
1996 R33 Series 2 Gts-t
-5 speed manual
-112 xxx kms
-Professionally resprayed by Candyman Spray Painting in Sydney in Jet Black
-Car gets regularly washed, polished and waxed using only top quality products
Brand New Engine Rebuild.
Consists of the following
CP Forged Pistons, Eagle Rods, Tomei Metal Head Gasket, All New Nissan Gaskets, Extensive Head Work, Head stud kit, N1 Oil Pump and Collar to suit, N1 Water Pump & Nismo Thermostat, HKS Step 1 Cams, HKS Cam Wheel, Z32 AFM, HKS GTRS Turbo, 555cc Injectors, Bosch Fuel Pump, Split Fire Coils. There is alot more that has gone into it, but this should give you an idea on the kind of quality parts that have been used. For exact specs on head work or any thing else please call me and i can put you in touch with the man who built it. I have spoken to many people with a similar setup who have 300rwkw on a sain amount of boost, so that is my aim. The above work/ parts cost me 20K,( with receipts) and has an engineers cert to boot.
Now Tuned @ 271 rwkw
Others Mods etc:
•Genuine Gtr bodykit (Plastic, Gtr copies are made from fibre glass)
•Carbon Fibre reverse scoop bonnet sprayed with a clear coat (with bonnet pins)
•17†Volk EMU Racing rims resprayed in Gold fitted with near new Hankook K104 255x40 (rear) Bridgestone RE01 215x45 (front)
•Tein height adjustable coilover suspension, hard but not uncomfortable
*Cusco Front Strut Brace
•DBA4000 slotted rotors front and rear
•DS2500 front brake pads, RACEBRAKES rear brake pads
•Cusco castor rods set to 8 degrees castor
•GFB Stealth Fx blow off valve (fully adjustable, can be fully closed)
•3†split dump/front pipe (fitted 3 weeks ago) into 3†CATCO hi flow cat (fitted 4 months ago) continues into 4†through to 7†cannon with 5†fluted tip, also have a legal bolt on end muffler.
•Power FC & Hand Controller
•Apexi AVCR Boost Controller
•Apexi Turbo Timer
•Apexi boost gauge
•Apexi pod filter
•Twin thermo fan set-up with 1x12†& 1x14†fans
*New Battery
•Genuine C’s shortshift kit
•Aftermarket steering wheel, pedals and Gear Knob
*Nismo Clear Indicators
*Aluminium wheel nuts
•Stock diff re-shimmined
•Hybrid Tube & Fin 700x300x75 FMIC fitted
•Excedy 5 Puk Ceramic clutch with RPM brass button pressure plate
*New stereo inc, Alpine MP3/ Ipod Control Head Unit, Alpine V12 amp running 6 inch Kenwood splits in the front and a Soundstream SPL 12" sub.
There is more as well, but i think you get the idea by now, this car has everything you could ask for and will cost you
ALOT less to buy than what it cost me to buy and build.
Pics of car and build attached to next post, please just ask if you want to see other pics etc.
Custom Plates SLO33R included in sale
$26,000 ono (remember engine work alone is over 20K)
or $18,000 with standard motor and turbo..
Phone Ben 0409 910 960
Edited by DRAGTS
i also have a pic showing engine number (on request) with these build pics, so you know your not just looking at some random photo's
Edited by DRAGTS
Great setup you've created there, i'm interested to know where you bought the bonnet,looks tough..
Good luck with your sale...
Cheers
Yeah thanks, the bonnet was on the car when i brought it so i'm not so sure, but i think unique autosports in sydney have the same or similar.. cheers
Free bump Ben!
I've seen this engine in various stages of build, and can definitely vouch for the quality of parts and workmanship that has gone into the build.
The guy who put this together has to be one of the finest and most passionate Skyline mechanics in the country.
Ok guys, some nice offers coming my way, none of them quite what i'm after, but keep em coming, i'm open to ideas.
By the way, i've got 700k's up on the new motor, so not too long before i get her tuned up.
Will sell now, untuned for 27k. Cheers!
Ok guys time for a bump. To celebrate the occaision, i have dropped the price $4,000.
Have a look at the mods, and realise just how good a value this baby is. Still planning on coming to the SNS next week if you want to look at it.
    • Yeah, whenever I say "HP", I mean HP. As in, at the engine. Allowing for a 25% discount from engine to typical Ozzie braked roller dyno figures, then subtracting the usual (more optimistic) US inertia dyno offset..... you get into the 600 actual engine HP territory from your 484 wheel number. 484 / 0.75 = 645   (that's Aussie rw intertia HP, converting to approximate engine HP. 645 --> 600 is discount for inertia dyno. Could actually be worse than that. But that would still be up around 600. So near enough for purposes.
    • Still fast enough to have fun (kinda). Time for a modern turbo with a divided turbine housing and a proper twin scroll manifold. I think 400-450kW is a great place to be, provided it's all in before 4500 rpm.
    • i'm not at 600 though 😢 its 484hp (356kw) at the wheels..
    • Nice. 600ish HP is probably a nice place to be.
    • In the US the EPA has been going after shops that sold aftermarket ECU tuning software that allowed you to disable CELs for things like EGR, DPF, SCR, or TWC failure. They also went after shops for selling emissions delete equipment. Their logic is that all cars built for street use have this emissions equipment and you cannot do an after the fact conversion to an off-road vehicle not intended for street use. Cobb, Hondata, and similar companies have basically all revised their tuning software such that going forward you cannot suppress DTCs for emissions-critical systems, nor can you toggle systems on and off in the tune like EGR. You also cannot adjust OBD emissions monitoring logic. You can still tune these cars. But you have to do things the hard way, basically. For example Subaru FA20DITs used to delete the TGV system to get spare analog IO for a flex fuel sensor. EGR also has to be dramatically pared back because without the TGVs the stock EGR map causes bad misfires. Now instead they have to implement the flex fuel system as a CAN bus sensor instead. IMO, this is heavy-handed but the EPA in the US gave so much leeway for so long and the aftermarket relentlessly abused that leeway to the point that they could actually see the effects of all these emissions-deleted work trucks on their air quality monitoring for cities that haven't met Clean Air Act standards. It's one thing to have a few people deleting emissions on their weekend car that spends 9 months out of the year on jack stands. It's another thing entirely for entire fleets of tradies driving around 8 hours a day on deleted diesels that emit 1000x the emissions per mile of a compliant vehicle.
