I don't think it is possible to put the RWD RB25DET engine into a GTS-4, but you can put in the engine from the Four wheel drive turbo stagea, so it is possible to get a 4wd RB25det. I want a Rb26det transplant tho :P. But it is still too epensive to do, so i will most likely one day soon sell the beast and buy a Cheap R32 GTR.
Greg.
u can lornch the gts4 just like a wrx/evo thats y when i was out at the toyota nat at dubbo i was beating cars with 100kw at wheels down the drag strip and thay didnt think it wood happen
i sterd shit when i ternd up and i sterd them u even more when i got the 3 fastes time out ov 25 cars with a 8.72s to 1/8mil
i was launching at about 55oo was just braking trackion that was all 4, at 5800 i was geting to much wheel spin and losing to much time but it felt good with the frunt tyers grabing and jumping side ways all looks good on the video thow
iv found that if u dont let the car go under 5000 it will bog down to much and the time will b slow
out a dubbo we had the track all day and u only had to waite for around 20mins be for u were heading down the track this was good to test things the cost for the day was only $117
My 4wd light only use to come on when i started the car, for about 30sec. I then got a new clutch put in and now the light is always on.. .Did they *** sumthing up? I know that 4wd is still working cuz when i break traction the front of the car "hops" from the front wheels spinning.
by the time u have the cluch on the way out the car has all ready been told that it will need more frunt tork at this rpm it will send it 50/50 giving u a wrx/evo launch
buy the time ur in to 2 the car will start to bring the tork back to normel
its dust all was cume in when u lose traction it will come in when ur driveing down the hightway if u realy get in to it not haveing a gauge wood not help to c this
i can drift my car and as i pass the apex i punch the throtel and this will tell the ecu that i need frunt tork and will straten me up for a clan exit
  • 4 weeks later...
Damn Straight..!
Mine Launches hard of the lights ...
esp now i have a nice big clutch...
beats most cars in 1st...
Second isnt as good as fisrt
but i still manage 100kms in Second. 0-100 8.3 secs
Apexi AFC does great things for my gts4.
Nothing better than kicking everyones arse in the wet!! 8-)
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to more wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
    • I put Whiteline pineapples in my old 33, they came in a 6 pack of them, got rid of the axle tramp altogether, cheap, quick and easy install,  they were pretty solid units though...???high durometer???? and NVH was increased a fair bit How hard are the ones you installed?
