Shuffle through:<a href="http://www.uras.com.au/" target="_blank">
</a>
and go to the aero spec bodykit page and you will see the R33 range of kits. at the bottom i thought they had accidentally put a 34 image in the 33 gallery but nope. It's a 33 alright with 34 front wing/ bonet/ lights/ front bar and that would look awsome imo since it has the best of both.
this one:
Problem is that website comes up with code crap instead of infomation for me so i can't read what part on there it is selling??
Anyone have any other info on this 'package' or if it's a one off???????
I found this website with more pics of this conversion, it's called an R334.
http://www.gtfactory.jp/poweredbymax/gallery/album03
sleekness of the 33 with the eyes of the 34. :pwned:
Edited by deant1
https://www.sau.com.au/forums/topic/167574-skyline-r33-with-34-front-end/
its a conversion that kit that is on there. fair few grand indeed, like 8-10 i think some thread was saying a while ago.
its a bit of work cos they have to mod the bonnet to suit and radiator support wall, as well as the guards to suit the doors and front bar. its a f*#k load of work but still looks sexy as.
Seems you can buy the whole kit after all!!!!! looks like a good option since it looks better than an R33 and an R34 imo.
http://translate.google.com/translate?hl=e...e%2Br%26hl%3Den
Front face kit
97,650 Yen front bumpers
81,900 Yen front fenders
115,500 Yen bonnets
292,950 Yen in set price
Rear wide kit
75,600 Yen rear bumpers
103,950 Yen rear fenders
81,900 Yen side steps
243,600 Yen in set price
B334R full kit
Front face kit
Rear wide kit
522,900 Yen in full kit price
so what's that in aussy? like 3 grand for a 34 front end... or 5 grand for a whole GTS T widebody aswell, pretty good i think considering how big the difference is.
Lights from a wreckers? not sure how much they would cost.
R33 GTR with 34 front end = perfection :D
Edited by deant1
dont forget labour, its a big job seeing as most/all of the parts would have to be modified to fit, be around $10,000 total if not more for parts and labour
Umn labour would be just like fitting a standard kit i rekon, do it yourself. Uras said the lights are bolt on and the kit from bee*r is a R33.4 kit so it's already modified and ready to go.
thats a bee-r kit i think? i think someone like garage 13 and stuff do the conversion also. but its a fair few grand. would look nice with some pumped gaurds.
it is a URAS kit, for information try the aussie website www.uras.com.au and email us if you would like more info. They are on special for $600 ATM all you need extra is front lights, bonnet and bumper. i have done a few of these now and it is an easy bolt on affair.
the gaurds are 30mm larger than std. (similar to gtr)
Edited by URAS
so if im thinking right the front bar and bonet is your choice. For example; if you want a gtr 34 front end you buy a 34 bonet and bar and if you want a GTT (no idea why) you would buy a GTT bonet and bar? when you say it's a bolt on affair is there actually much work that needs to be done? Since i live in adelaide and would have to get someone to fit all this for me!! any suggestions?
cheers.
Also URAS, with your front fenders on do the normal sideskirts for the car still fit? example if it's a GTR 33 do GTR33 skirts fit or do they now require modification to fit the URAS fenders?
Edited by deant1
    • I have had the r3c in for years now, maybe close to 7 years and it has never missed a beat, anyone can drive it. Super easy to drive around town, the hotter it gets does get a little hard but it holds the power easy as
    • Shit thing to find eh? I guess the big issue is that whatever "fix" you do now, it might slow the rust down but won't fix it. I just wanted to add that in no way is fixing sheet metal in 3 dimensions the place to start with welding....that is a pro only job because its too hard to work out where things should be, let alone doing a clean enough job that it can look OK and still be strong too.  I needed to get a new rear quarter panel on the GTR and it took a pro weeks to get the old one off cleanly, new one on in the right place and looking somewhat like it should have with most of the previous connecting panels in place. Gluing a couple of bits of metal together with a welder in the garage is doable, but that is totally different to doing panel  replacement
    • This seems to be a very popular swap since all the turbo skyline prices went through the roof! I'll let someone more familiar chime in, but I understand that yes you probably want to swap the loom in to swap out the auto TCM stuff. You should not assume everything just plugs in either, you need to check at least the ECU wiring diagram for any differences at the plug at the left headlight and probably the ones near the ECU that join the dash loom too
    • hows it fellas, my first post here which seems crazy cos half the forums i read are like the same age as me haha. to make a long story short ive got an r34 sedan (rb25de neo auto) which im swapping to a s0/s1? rb25det, r33 big box and nismo gt pro lsd. i have the motor and gearbox all bolted up outside the car, old motor and trans out. i bought the motor with stock ecu and loom, do i switch over to that? or will it be easier to get a r34 manual ecu and keep the loom if thats even possible.  also engine mounts look different, anything else thats different or incompatible? cheers, hope this all makes sense Paddy
    • att.4QNbuJlz_gNZPFBGFqeEvxSUHXkGt7z40V59MrtXTPg.mp4
