just curious because my mate has just got hold of a 30 block and wants to put it in his r34... but has heard that the neo head is not a good option because of the shim and bucket set up inside the head(aluminum intake buckets).
https://www.sau.com.au/forums/topic/167582-hybrid-2530-neo-r34/
Doing one at the moment, i feel they are definately superior to the r33 head fr that reason. Ive fitted gtr cams. You just have to cc the head, as the bowls are much smaller than the r33 head, so you end up using rb30et turbo pistons and end up with mid 8's comp.
  • 4 weeks later...
He's sourced a good bottom end, and thats at the machine shop.
At the moment he's aiming for around 600hp at the crank.
Still deciding on turbo.
RB30E block
Stock crank prepped, balanced etc.
stock rods(na RB30)
ACL bearings
RB26 ARIAS pistons 86.5mm
total seal rings
Head R34 neo RB25
plazma man intake manifold
tomei 260 poncams
70 hp nos system
  • 3 months later...
im also thinking about using my neo head....because they have smaller combustion chamber means that the comp ratio will be higher then that off a r33? I need alittle help in finding the right pistions to give the best comp ration...Will be using t04z and pushing 2.2 bar max...I would still use my hks gasket 1.2mm...
cheers
Whats the question? rb30 pistons wont cut it, the comp ends up too high. If you plan on using a 1.2m headgasket to drop it, it wont be anywhere enough, and is the wrong way of going about it. RB30ET forged pistons work out about right in the comp, at between 8.3 and 8.6 depending on what headgasket you use, how much the head/block get skimmed during the build, and the specific brand of piston.
email me for any info you require.
The RB26 pistons will give very high comp ratio due to the R34's small combustion chamber.
They are not an option really.
Yep, he ain't using those pistons anymore, as they are wrong for the job......
    • Seemed to be good when Jeff owned it but they did a shit job on my car, probably worth a think before spending 10's of thousands of dollars where they might be cutting corners
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
