  • Replies 50
Paul,
Yeah it does seem like that's what he's done. The car is lifeless.
Moonus,
I checked the cat, the honeycomb thing is still intact but its just a standard hiflow one with 3" ends, maybe i should try metal cat. He said it's getting enough fuel, and we also got new spark plugs in there. but a colder 7 range. would that affect it?
sounds like something is holding it back.
The thing is if i get someone else to tune it, then i may have to fork out around $200 and what if the next tuner says the same thing or they can't find the problem. i don't mind paying $200 for a tune if the problem goes away or if they find the problem.
I have to ask, do you have a standard dump and what boost controller do you run? Which intercooler? I had exactly the same problem, now solved.Try to remember the hiflow is not a very efficient exhaust housing and can cause problems in this timing area.I don`t care what people say, the power is usually limited to 220kw but I will concede some have done better.Which is why i ask about setup. :P
skylinecouple,
I got one of those 3" bellmouth front/dump pipe in one. I'm running a Greddy profec B II boost controller and a Hybrid intercooler( has a limited edition drift plague on it if that means anything). However the intercooler is sitting behind the stock serie 1 front bar ( for stealth) i was told this should be ok, as it's not a track car and i won't be running that much power.
How did you fix your problem? I don't really mind if the peak power is only 220rwkw, but the midrange is just dreadful. There is no kick. Just for interest sake i had a rolling run (2nd gear) with my mate who has a stock turbo and he was keeping up with me.
Before the detune the car had massive midrange and then would ping up top. but now it doesnt ping but no midrange..
what mods have you done to yours? what power?
Take it back to matty...( i also got tuned from hitman, highly recommended.)
I am suffering from the same issue sometimes? in the cold weather only?
The boost is rising in the more then perfect conditions(very cold). The solution for me is to get a boost control device to stop this from occuring.
Eg. On a hot day it runs better then in the cold weather?
Cheers
my tuner said that the PFC is self correcting it and pulling it back to protect the engine.
That was so funny I just pooped a little.
Sorry to say this, but your tuner doesn't know what he's doing. Sure you like him and you feel bad taking the car somewhere else, but is that important enough to you to let him potentially DAMAGE YOUR MOTOR? Would you feel better then?
PFCs have no knock retard. None. They can flash the check engine light at you but unless you move that right foot of yours the car will ping itself to death.
multiple batches of bad fuel is unlikely, unless you filled up from the same place or got unlucky and filled up at 2 servos when a petrol tanker was dumping fuel and stirring up all the crap in the servo's underground tanks.
One of my friends had his car tuned by someone who was a "really nice guy" - turns out the tune was dangerously lean. Always take it to someone who knows their stuff.
Thanks for all the replies. I have spoken to Adam from JEM (JEM did not tune my car) who told me that he knows and respects the person who tuned my car. he said that the problem is more than likely mechanical rather than tuning.
He said this is an odd problem, which cannot be fixed with any tuning.
I read in a HPI mag where they were tuning their R32 project car, and with the GTR hi flow cat it was pinging but then the pinging stopped when they changed to a metal cat.
I then spoke to Indy from ISMOtor racing and he said that i should not be running that much boost throguh stock internals. i should only be running 14psi max!!
Either way he was keen to get to the bottom of the problem and said bring the car in and he will check it out.
So i will arange to take it to him soon.
The only thing is how do i know if my PFC has been locked by the previous tuner?
Meh, i've got friends running more than that (16+psi, 270rwkw). The thing to remember is that the candle that burns twice as bright lasts half as long. Maybe you can run 14psi for 3 years, 18psi for 1 year and 20psi for 6 months after which you need a rebuild. I pulled those numbers out of my bum, when you start to lean on the motor hard your tune becomes very important.
Deffinately take the car else where mate. My guess is your tuner is unfamiliar with the powerfc and doesnt know how to tune it properly. With the knock levels you were experiences you could kill your engine pretty quickly.
it wont pull timing as water temp goes up, once water temp is 80deg or higher correction is 1.0 (so no correction)
in fact, it actually advances the timing and runs richer under 80deg to get the engine to optimum temp
i dont see a correlation to knocking and water temp or 80deg ?
My Old tuner said that when my car is pinging, the water temp rises to about 90. usually it is around 84.
He said that when it detects a rise in water temp, the PFC will pull it back abit.
Is this true?
I have datalogit logs of mine pinging and it doesn't affect water temp.
IF water temp were to rise due to detonation it would have to be rattling extremely bad which would most definitely = blown ring lands within a very short period of time.
Your tuner is a worry if that is really what he has stated.. Take it some where else before you loose a motor.
Mate i got my tune done by Adam too, great bloke and really does know his stuff. I had the same problem and all it turned out to be was a massive air leak from my carbon canister! Car still does ping high every now and again but also found out my cat conv is still only 2.5 inch and the exhaust is 3inch so thats next to get done.
Yep,
Try a new tuner. I had a niggling pinging problem with my car after I fitted the cams.
Road tuned the knock as much as we could, but still not perfect.
Took the car to Racepace (along with a new turbo, injectors etc) and the thing is perfect. NEVER knocks.
Adzmax had a similar problem. Just a tune and exhaust. Had a tune from a reasonable shop but was never happy with it.
Took it to the right tuner and picked up enormous amounts of power through the midrange.
Some tuners know what they are doing more than others.
Try a new tuner. Pay as much as you have to to take your car to the best tuner. You will walk out as happy as larry.
    • I have two German Shepherds that like to bite things that are in places they shouldn't be. Plus the cars/batteries on chargers are inside a locked garage, inside that fully fenced and locked yard. If you can get the car out, you can have it, as I'll be having one hell of a laugh at your expense.
    • Looks like they changed the wording in the manual for the new model. I have a different model. Mine is CC1206. Not CC1206-XLI. Mine doesn't support lithium at all. I can't find the manual for my model online and they don't list the model on the Century website anymore either. In my manual it says what I quoted and that they recommend to not leave it on 🤷‍♂️ Sounds like you'd be fine with this one now.
    • Thanks for actually answering every single point! I noticed the date only after posting. And yes, looks like things have changed a little bit since then. FWIW, looks like Government Gazette No 253 has the current emissions test procedure. Sounds pretty reasonable altogether. One thing I learned from this is that it's possible to check whether a catalyst does any work by measuring the temperature. Catalyst outlet temp is at least 40°C higher than inlet temps if there is a reaction happening. I'd be curious to check this on mine but don't have a thermometer. Because purely going by smell it can't be doing much. Personally I'd be okay to pay for the test as long as it's within reason. My main concern would be to lose my rego because it definitely wouldn't pass the test in its current state. I'll see if I can do a bit more digging and see what's involved in doing this nowadays.   To be fair I don't think it's stopping many people from doing the modifications anyway. It just puts a barrier up to doing things right
    • Uhhh if anyone sees this - I bought a BRZ years ago, on my fulls soon so back on the market for the R34!
    • Research research research, and tackle the important things first, like the rust, because as a wise old hippie and some crazy horses once said "rust never sleeps" Nothing good comes easy and fast, and nothing that comes easy and fast is typically good
