Just a tid bit of advice. While first thought would be that the funnelling of all that surface area into a relatively small diameter hole will give you lots of airflow to the brakes/rotors. it probably wont. Most likley you will get a lots of turblulence and reduced airflow. (also increases sc)
Be interesting to see how it goesss. but i would think you are better with a flush panel, whereby helping the cd of the car...and having an opening essentialy the same diam as the duct you are going to run. Its normally the best compromise.
Roy,
All fair points mate and i do tend to agree with you. The reason for them being so big is that i am going to run another duct from each fibreglass panel to the other side of the rotor, the ones you see are for the caliper. I thought that 2 would be better than 1, just waiting on more ducting to arrive.
The inlet you see is 75mm so not small but not huge either. I also do test how much air i get through these with my big f#$& off fan that we use to cool the car down after each run as the pit garages are air conditioned it helps cooling everything down under the car, pic below
The reason is that we do run in temps over 40, yesterday was 46 while i was doing this mod near killed me.
was a problem point and still not where i would like it.
Last time out i ran with the alloy radiator, standard fan, no shroud and a N1 water pump, ambient was 40 degree and i was a little hot with both the after market temp gauge in the engine out let and the Power FC both showing 96 max. Still a bit hotter than i would like but its really too hot to run these cars at that temp, intake temps and knock are the pits mate.
need to update my other thread on this topic too
Yer thanks but i still have top put put the second inlet in the duct and it was easier to do with the front bar back on the car. not to mention quite a bit of filler to put in and sanding to do as you can see
Edited by tacker
nearly finished still have to run two more ducts back to the fronts but made a real difference to the rotor temps and brake pads. No more white edges on the pads any more. and then some better rear ones and thats it
Got my act together last night and finished the running of the brake ducts to the font brakes last night.
Also as an after though i put in some CAI which i hope will work, i guess it got to help.
Interesting setup.. I'd be interested in whether channeling the air into such a small defined space is any better than the general flow effect over the wider area.. e.g. just removing the splash guards and allowing the air to pass through.
    • I replaced the whole clutch line with the chase bays braided hose, I think it removes that loop, is it the short hose that comes immediately off the slave or is there a drawing in the manual to find what you’re referring to? It was just re-bled when I upgraded to the nismo slave, old slave worked fine but I thought that might help, didn’t change a thing. It’s like the first half of the pedal is pushing air and then when it finally actuates the master the friction zone is tiny. Makes it practically impossible to launch the car
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
