So was it on, as i missed it :(
I spoke to the reporter yesterday, he said it got pushed back because there was a number of 'breaking news' stories this week.
He recons it will be on either tonight (I hope not 'coz no one watches on a Friday) or Monday night.
Mal called, and told me to switch channel, so i did. All i saw was vids of hoons, Kev very briefly say something about driver education and the echo doing two 360 turns. That's it! :P I saw more hoon vids than anything else :)
And Mal said Bec was seen very briefly, and not even driving :P
Yay was finally on....Go Bec :).....was only on briefly including a little shot behind the wheel having a good laugh :thumbsup:
What I was disappointed with was that they turned it into a hoon story WTF??? The arguement was that they shouldn't be teaching people those kind of skills as they will just do it on the roads. I'll put that in the same basket with the poli's arguement that we shouldn't put young drivers thru a defensive driving course to save their lives as they will be overconfident on the road :whistling:
I just ripped the feathers out of my pillow. Just need some tar and a mob of angry ACA viewers. Truly sad the spin put on things. Actually disgusting really. Make you wonder what else are they trying to shape our views on
To be honest it doesn't really worry me too much, people aren't stupid, it's pretty obvious we dont run a Hoon driving course.
I guess it was a little dumb of me to believe them when they said they weren't going to put a hoon spin on it.
Its very disappointing to see the Media doing a back flip on your kev.. Hope you still get some business out of it at the end of the day even if its not some of the more preferred business you would like... P.S if you please to go to noble maccas on 2 wheels can you let me know i want to come watch :thumbsup:
People are stupid, they watch ACA and TT.
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
