****** FOR PICS GO HERE : http://www.skylinesaustralia.com/forums/in...howtopic=167288 *******************
I've had a change of jobs so I am forced to sell off the beasty.
It has looks , handles and is ready to cope with a power upgrade as a simple bolt on. It goes pretty well and has run a 13.3 1/4 mile without the addition of the S-AFC NEO, throw a tune at it and it may just run a high 12. Bolt an Rb25 turbo on and it should be easy.
This car has appeared in Perth Street car last year, so it's more than just a neat R32.
Custom BBK Black with silver Flake Respray ,Fully detailed engine bay.Body kit.
1989 R32 Gtst Coupe RB20det manual 114000kms
Engine & power mods
600x300x75mm fmic with custom poilshed stainless piping
Greddy Profec B spec 2 EBC
Apexi Super AFC NEO
Blitz BOV
3" stainless front pipe (thermo wrapped) with decat pipe , 80mm cat back with x force muffler
Oil cooler with remote filter
Ross Autoclutch 9 Puck ceramic button clutch
5 spd with redline oil
Braided Stainless clutch line
Alloy Catch can
K/n filter with stainless CAI partition.
GTR Fuel pump with direct wiring modification to supply greater flow.
timing belt replaced as part of 100,000km major service.
Suspension & Wheels
Suspension setup to 'handle' , look pimped and with attention paid to grabbing excellent off the line traction.
Tein H/A full height and damper coilovers - rebuilt & re-valved to Australian spec
Adjustable Rear camber arms
adjustable front castor arms
Front and Rear Strut braces
HICAS lock bar
17x8 Gmax wheels with 225/45 and 235/45 tyres
Interior
HKS Direct Bright Boost, Oil temp + Pressure gauges
Apexi turbo timer
Grex gear knob
Full autowatch alarm /immob.
Clarion Cd player with 4x6" speakers and kenwood amp pioneer sub
SOLD
Other items that can be negotiated at additional cost if buyer wants a few upgrade bits for later ,will sell these sepparate;
* Rb25 turbo series 1.5 (made over 200rwkw) with all lines and elbow.
* R25DET Engine head to sump
* RB30 'turbo' block (already has oil/coolant feeds no need to modify) with rods & pistons, add to the Rb25det head for a RB30DET conversion.
Edited by rev210
https://www.sau.com.au/forums/topic/167623-sold/
    • You see R34 GTRs listed for 200-300k are they really selling for these prices? Kinda seems like the same ones listed all the time. Even with R33 GTSTs looking at gumtree. You have an auto with a bitsa interior for 35k. Another one needs an engine rebuild and asking 24k. And then you have a stock in better than average condition for 45k. Nobody is ever going to pay these prices.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
