hey everyone i am new to the forum, just thought id ask a quik question,
my r33 gts-4 automatic is having a major prob with gear selection,
il give the best description i can
park= normal operation but cant rev the car past 3000rpm as if it is stalling up in gear
reverse= acting as a neutral, doesnt move forward or back, and also wont rev past 3000 rpm
neutral= is selecting a forward gear
drive= operating as normal, shifting fine and revs out as it should in each gear
2nd= as normal
1st= as normal
basicly its a real headache as i cant reverse the car, just wondering wat yall think cauld be causing it, i have checked all the wiring and it all appears to be fine, has this been a problem with any other auto's? cheers Dan
i bought the car with this problem, the guy said it happened from sitting, which i didnt think was right, so i took it to nq automatics up here and they told me it was caused from the clutches slipping, and had got that hot that they had melted together, i have located another trans in townsville for a reasonable price, so my worries r gone for now
ah k i get ya now. he must have cained the shit out of it to get it that hot. MAKE SURE U FLUSH THE OIL COOLER LINES OUT WITH SOME SOLVENT, otherwise all the crap that has gone through the lines an blocked the cooler will melt your new box. also recomend putting an extra external oil cooler on it after the radiator
  • 3 weeks later...
    • So....to find any R chassis part number, get your VIN (will be something like ER33-xxxxxx for you) and go to: https://www.amayama.com/en/genuine-catalogs/nissan and enter it. From there you have access to a web version of Nissan's part system, FAST. It is a bit tricky to get used to, so maybe have a shot and post up what you think.  You can also search by general model but note in some cases your car might have different options so VIN is safest.  On diagram 211 I got 14075-75T16 for Connector, Water Hose If I search for part 14053‑21U10 that you posted, that is also a water hose but not the one bolted to the plenum and 14075‑04U00 is the fitting where the water hose goes into the block.
    • Yeah now we are talking I much prefer coolers in the front middle because it lessens the chance of a small bump to a corner stopping the whole event. I was thinking the AT cooler can move out of the radiator, delete the AT/engine coolant interwarmer and mount a separate cooler with a thermoswitch somewhere further back as is common in racing, that would be one thing. Beyond that, the engine oil cooler is an obvious one to move to the wheel arch, potentially one on each side, but unused space is an issue. I did have a earlier pic with the bumper off but it doesn't show how busy the corners are: DS is full of the auto driving sensors and PS is totally fully of windscreen washer fluid reservoir But ultimately I was hoping to keep the AC, and the water/air heat exchanger is fundamental so it is not just the radiator that needs to be in front BTW here's airflow to the rad as it ran at the track (one horn is gone now and I'll remove the lights next time):
    • your right the maps for Australia came out in 2017 but are 2010 maps. i got the updated maps SD card put it in and it was the same. Same maps in my Brothers Nissan Patrol. 2020 i think his car is
    • Yeahhhh, the costs have killed me. Spent more than the cost of an engine rebuild and it most mostly servicing and a tune lol.
