  • Replies 240
he has 2 offsprings now.
you coming to the dyno day with that lexus of yours, Josh?
PUPPY'S!! Do they like peanut butter too?
I don't own the Lexus now, sold it to a mate. It's all painted and got it's 20's back on though, it maybe at the dyno day as the guy wanted to come watch. I'll be with a couple of R32's.
Awesome guys...
Attached is the paperwork you will need to fill out to enter your car.
So can you please fill out this paperwork and put it in your glovebox so you dont forget it on the day.
(I have also attached this paperwork to the first post.)
SAU_DYNO_DAY_16TH_JUNE_2007.doc
YOUR KING OF WEAKSAUCE...
Thats enough talk about weaksauce, your both weaksauce as far as Im consirned as neither of you are running your cars...
Everyone whos on the list has earned the right to call you both weaksauce... :)
Grab a spoon everyone, caus u all can EAT MY ASS ;)
I told u months ago itd be better to have it later in the year, but ohwell
Everyone whos on the list has earned the right to call you both weaksauce... :P
haha.. u dnt scare me col..
*runs from scary man with mod stick.. and hides behind a couch..*
well i said col if it was on a sunday or weekday anyday but sat then i would.
1 week to go people.. pay money.. yo i wanna see more cars..
    • For your application, where you'll be at that 1/2" size or perhaps larger, yeah, excellent. Although not if you need a tight bending radius anywhere, because the corrugated stuff is not anywhere near as flexible as rubber/teflon cored stuff. But for turbo oil lines? No. Too big. They just don't do the corro stuff down at the ~1/4" ID size that you'd want, and if they did the OD of it would probably be a bit too fat for fitting it into the tight spaces available. I use hoses like that all the time for fuel gases (LPG, NG) and liquid fuels (HFO, diesels, waste oils). When we did the London Olympic cauldron, with the 204 individual burners on it, we had miles of the stuff (although a lot of that was teflon core). A bunch of that crap is still cluttering up the workshop, more than 2 years later!
    • Would something like this be an option  https://processhose.com/products/configurable-metal-hoses/1-2-in-t316-stainless-steel-annular-corrugated-configurable-flexible-metal-hose-assembly-with-ends-t304-single-braid-masterflex-af5550.html I'm looking at this for replacing the OEM EGR when installing a aftermarket intake plenum
    • The once piece tail shafts with cv type joints on either end are the ones that end up vibrating and the vibration is caused by the cv joint binding as it turns, I’ve also seen them explode from the binding
    • Take this with a pinch of salt, it's from someone (me) who got annoyed with turbos entirely. I hated aftermarket lines. If I had the option to use hardlines with whatever turbo I had - I would use them, 10/10, 100% of the time. The only reason people go larger, heat resistent, shielded lines etc is because they have to. And yes they don't last forever. Even if you spend big bucks on all the best heat shielding money can buy, with the best heat resistant, fuel resistant, oil resistant, radiation resistant hose, they get stiff and break down and just don't last the way a metal pipe will.
    • Unfortunately I am quite literally halfway across the globe. So all sources for parts like that are far away for me. What do you mean by that exactly?
