  • Replies 240
That's what I built the site in my signature for. It's not 100% accurate but it gives an indication of the differences in response and top end. I already uploaded my tuning graph from a few weeks ago so it would be good to see yours, MII32 (I think? sorry I didn't catch your name) and mine.
I haven't taken photos of my dyno graph yet, my camera's stuffed so have to borrow a cam from my mate first. I will have a look at the site u built on dyno graphing comparison~~ MII32? LoL i only have normal plates mate, name's Jyo, with the white gtr32.
Yeah, I know, I meant you, me and MII32 but I didn't catch his name. When Mark put his graph over mine the curves were very similar except mine came on earlier. Would be interesting to see all three.
Icic willo...no wonder i was a lil confused when i thought u didnt know who i was~~ :whistling: I think the "MII32" u r referring to is "DT GTR"(SA plate). That's Danh, his forumname here is 9krpm. Yeah it would be interesting to put all the curves with different twin setups together. That said, u guys whipped me by 40hp @ 4 wheels! I think i need to move on from poncams to procams, have a re-tune and get 6/4 brakes. LoL. But awesome results on yer 2530s mate~
That's the one. Saw the back end of too many cars on Saturday, they all start looking the same.
You're also running N1s so you'd expect to have less top end. I'd imagine your's would come in a lot sooner though. The problem a dyno day is you always come away wanting more. While I'm more than impressed with the 2530s so far some more aggressive cams and another 500-600 rpm to play with would be nice.
It was very interesting to see that too. Thanks Mark & Willo.
Your car setup is very nice!!!! What cam, pistons, rods and gearbox have you got in that beast?
I like ur midrange response. I am thinking of selling my engine and build a 2.8 late next year for track work.
Jyo curve has less power than mine at the bottom end as well but he is running more conservative boost compare to us. It's a shame that he is selling the car though. Hopefully it will go to a good home and we get to see it out on the track as often
HKS 264/9.15
CP Pistons 86.5
Crower rods
Standard BNR34 gearbox
I figure if Mark can squeeze 1100+hp out of a RB26 and I was already happy with the response of the 2530s I didn't need to go to the expense of a stroker. I think some bigger cams are in order though so I can lift the rev limit to around 8500rpm and hopefully squeeze some more out of the setup.
Nice work willo. how much boost are you running to get that power?
I've got the same cams and have been reving to 8.5krpm without any problem in the past 2 years. A larger cams might be good for the drag strip but may result in too much lag for the circuit, if not tuned properly. More power in the midrange will help me more on the track.
The 500hp run was at 20psi. All the head work done is good for 9000rpm but peak power comes on just before 8000rpm so there wasn't much point pushing it any further.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
