  • Replies 240
I should make an appearance, but I wont run as I know its power and I have came to the conclusion that I need more......its too depressing to see it with fark all power.
Ill let you pretend my car is yours if you like Chris...
Id do anything to help a buddy out... ;)
PAID POST updated
Col, please update your list in the first post, thanks :(
No worries :)
The list looks solid there Karen, I think we will be in for a great day...
3 more payments confirmed via pm that are yet to clear so we have got quite a few cars running, better late than never...
Thanks guys for getting your payments in so we can get this thing going... :)
I cant wait to see Marks GTR scream out 1000hp... :yes:
Your car is getting as rare as shanes these days Andy... :)
See you on the weekend... :D
now thats just low :P ha ha
If you really want to see it drive by Allstar you will see it there all on its lonesome :)
Your car is getting as rare as shanes these days Andy... :P
See you on the weekend... :)
now thats just low :) ha ha
i hope u pair die a horrible death :D
too late to put my hand up for a spot?
i can send the bucks through now or pay on the day..
I would have to leave around 1pm though as i got 2 house warmings to go to that day..
would someone like me to install a slide highflow and wind up a bar.? ull see around 180 :) ...
my 180 lacks powah.. :)
and same to u.. but even more horrible.
if ur coming from the south whats the best way to get ther..?
jump on whereis.com and see what it says, best way to find out mate :D
it's ok marki, i'll be there tomorrow to give you shit :iluvff:
Wooty Woot! Job cancelation means I can make it after i get through some dickin around in the am. :D
Will be good to see you there pal. Although by the sound of things you wont be running hey? What about skidpan next saturday?
Awesome, see you all tomorrow.
For all skylines may I suggest to enter the property via the first gate...
As the main gate down to the workshop has a rough speed bump which may catch a front bar or two...
So please use the unlocked gate 50 metres back from Godzillas driveway and then drive roudn the back of the shed...
If you lost and dont know what to do, pull up and walk down and Ill direct you where to go if your too low... :)
Also SAU Qld were not able to secure a BBQ in time for this event. So there will be no lunch served.
There are the usuall fast food shops all within 5 minutes drive tho :nyaanyaa:
See you all round 10am :domokun:
Those who need to leave before the finish of the day please advise me so we can put your car up the que.
Also please dont forget your cameras and video cameras so you can post it up after the day to show everyone how awesome it really was. I will most likelly be too musy to take photos or video this time, but ill try.
Also Marks GTR has no gearbox in it atm, so it wont be running. However he has lined up 4-5 really hot customer cars which will blow your socks off. There is only one thing better than a 1000hp gtr, and thats 4 GTR's with more than 500hp each... ;)
    • Hi all. So I have my GTR on the lift and have been working on it a few days and yesterday I unpacked the frontpipe that was wrapped with heat wrap stuff, because part of it was breaking down and soaked in oil. Noticed that the pipe itself does not actually look like a Mines, despite it supposedly being a Mines. But I could not find any fronpipe online that looks exacly like his, and I don't think it is a custom one. My amateur measurement also showed the two pipes are about equal length, so maybe this is just an old version of the Mines pipe? Would appreciate insight on this by the enlightened folks. greetings from Germany
    • Yeah. If I plug the connector in and connect the vacuum lines, I assume worse case scenario is that it simply doesn't work? Yep PFC.
    • I would think that rather than attempting to perform an engine swap, with all the difficulties associated with doing so in a country where the raw materials required are harder to get hold of, I would just build the CA20 for boost, find an EFI manifold for it and either add a turbo or a supercharger. Or both. You replace one set of difficulties with a different set, but I know which would be more fun.
    • Well, a proper aftermarket ECU** SHOULD be set up to run the purge solenoid, same as the factory ECU would, so that the tank breather system continues to operate the way it is supposed to. I have no knowledge of whether the PFC (which is what I assume you mean when you say Apexi) has an output (and internal logic) to run the purge solenoid. If it does not, then given the product design intent for the PFC, which is to be a plug in replacement for the stock ECU, I would consider that a massive failing on Apexi's behalf and would be another reason to think that they were a half-arsed solution to the problem if programmable management on RBs. I would suggest that since Nistune came to market (which is a LOOOOONG time ago now) there has been no valid argument for choosing a PFC, especially if the PFC can't do things like this.   **ie, Haltach, Link, Motec, etc
    • Thanks for asking the question we were all thinking!
