PROBLEM FIXED...for all those wondering timing belt jumped 4 teeth!!!!!!!!!!!!!.....yes i know i dont believe it either...but sure enough we took it apart and bam it was all out...put it back together and she is beautiful!!!!!!!!!!!!!!!1
hi guys
ive got an rb20det r32
it was non turbo auto and is now manual turbo...
everything was going fine...would fry the tyres without any trouble at all!
one day i was driving along and hit a massive bump in the road...
ever since the car has completely changed
its started to miss straight away.....throughout the whole rev range
idle is absolutely disgusting...just missing and rough as...and the worse problem is the car has 0! power....a charade would flog the pants off me...it drives and sounds EXACTLY like and naturally aspirated rb20..deep and throaty sound
BUT ALSO pings like nothing else from about 4k onwards
list of things we have tried
changed cas
changed ignitor
changed coilpacks
changed knock sensor
changed o2 sensor
changed ecu
changed afm
changed plugs
wiggled all wires on the car and it made not difference
inspected turbo
pulled exhaust off
tested fuel pressure
checked boost pressure is running 8psi which it should be
now a couple of weird things!
i retarded the timing as far a it could go...this stopped the pinging a little bit...and allowed the car to rev smoothly...but still is the slowest rb20det on this planet
the only thing we can think of now is that the timing belt jumped a tooth or something ridiculous
does anybody know anything else to try
symptoms again are
VERY slow
pinging
missing
very rough idle
sounds like an NA rb20
car is quieter now to i might add
Edited by heyhey!
https://www.sau.com.au/forums/topic/167673-extreemly-weird-problem/
hi guys
changed cas
changed ignitor
changed coilpacks
changed o2 sensor
changed ecu
changed afm
changed plugs
inspected turbo
pulled exhaust off
symptoms again are
VERY slow
pinging
missing
very rough idle
Hi...
where did you say that 'bump' in the road was??....I need my car to be a bit quieter!!! :teehee:
anyway, hope you find a result!!
NA engines usually have a higher compression than turbo engines, id say get it looked at by a mechanic, it wouldnt hurt to have a compression and/or leakdown done on it at least this may give a little comfort as well.
Also there is a couple of things you could check, intercoolet piping and joiners.
Good luck with it
Good luck with it
Hi DA21 !!
I'd like to know more about your car (if that's ok?)!!...sounds hot and interesting!!!
Superspit!
I'm having a similar problem, I checked the ecu codes and got #11, and #21, crank sensor, and ign. circuit. My engine is a RB20DE conversion to DET and my problem started very similar to yours. Check to see if you have any fouled plugs, my #6 cylinder is not firing at all although the coils and plugs, etc. are fine.
If it cracks between two pistons u wont lose any water or oil it will just have bad compression , u have tried just about every other problem just other thing to look at
Hello,
Just a few suggestions..might have been covered but hope I can be of some help
No noise from the fuel pump.?...could be on the way out.
Fuel filter could be blocked....how does she run at idol?
Could one of your injectors be cracked or become faulty after the knock?
if you have checked these...take it down to a workshop.
Cheers Tekin
hi guys keep the comments coming.....
ok possible it could be blown head gasket...might be somethign to look at last id say
fuel pump is making normal noises...fuel pressure was pretty good!
injectors...very likely i would say...its definatly possible some are clogged
what do people think regarding a timing belt jump???
  • 5 weeks later...
    • I don't really know general street pads too well, but there is no reason you can't get a low dust, long wearing, no squeal pad that works for those calipers at a reasonable price....they would just be a low end to medium price daily style pad.  If new pads don't have much bite or they loose it over time, it is probably just the pad glazing up which you can fix by giving them a good thrashing every now and then (or get the mechanic to deglaze them at next service) Track or semi track pads are where you have to put up with excessive dust (and potentially squealing as a side effect of that) in return for good bite and performance when very hot. Street pads have nothing like that sort of punishment, even long downhills with the brakes on are easier than a track session
    • lol yeah I'll check that, reminds me of the LDV thread!  I don't think that is the problem here, the starter doesn't even solenoid click. I did do a super quick test by removing the starter motor's power cable from the engine bay fuse box and the battery voltage was still 10v, so something super fishy is going on. BTW here is a R33 fuse box table I threw together from a few sources....use at own risk! R33 Fuse Box and Sources.xlsx
    • Johnny's approach, throw all the Nissan electronics into the trash. Best thing I've done to my shit box, go DBW.
    • Sounds like the JAX guys must have installed some really awful pads, are they BenShit/BenDicks pads by any chance?
    • Result of another R35GTR build. Similar specs as above except this is running our bigger size SS-2 profile option. Made similar power except this car runs on Pump 98 fuel. Build specs are: Nissan R35 GTR 2015 model stock engine and box. ETS street intercooler boost logi intercooler piping with tial bov, boost logi turbo inlet pipe ID 1050 injector DW 300C fuel pump Decatted oem down pipe and y pipe& HKS exaust 3inch intake pipe Upgraded actautors HyperGear SS-2 high flow option Final result is 639whp / 477wkws hubs, Ron 93 / P98 fuel at 20psi.
