PROBLEM FIXED...for all those wondering timing belt jumped 4 teeth!!!!!!!!!!!!!.....yes i know i dont believe it either...but sure enough we took it apart and bam it was all out...put it back together and she is beautiful!!!!!!!!!!!!!!!1
hi guys
ive got an rb20det r32
it was non turbo auto and is now manual turbo...
everything was going fine...would fry the tyres without any trouble at all!
one day i was driving along and hit a massive bump in the road...
ever since the car has completely changed
its started to miss straight away.....throughout the whole rev range
idle is absolutely disgusting...just missing and rough as...and the worse problem is the car has 0! power....a charade would flog the pants off me...it drives and sounds EXACTLY like and naturally aspirated rb20..deep and throaty sound
BUT ALSO pings like nothing else from about 4k onwards
list of things we have tried
changed cas
changed ignitor
changed coilpacks
changed knock sensor
changed o2 sensor
changed ecu
changed afm
changed plugs
wiggled all wires on the car and it made not difference
inspected turbo
pulled exhaust off
tested fuel pressure
checked boost pressure is running 8psi which it should be
now a couple of weird things!
i retarded the timing as far a it could go...this stopped the pinging a little bit...and allowed the car to rev smoothly...but still is the slowest rb20det on this planet
the only thing we can think of now is that the timing belt jumped a tooth or something ridiculous
does anybody know anything else to try
symptoms again are
VERY slow
pinging
missing
very rough idle
sounds like an NA rb20
car is quieter now to i might add
Edited by heyhey!
https://www.sau.com.au/forums/topic/167673-extreemly-weird-problem/
hi guys
changed cas
changed ignitor
changed coilpacks
changed o2 sensor
changed ecu
changed afm
changed plugs
inspected turbo
pulled exhaust off
symptoms again are
VERY slow
pinging
missing
very rough idle
Hi...
where did you say that 'bump' in the road was??....I need my car to be a bit quieter!!! :teehee:
anyway, hope you find a result!!
NA engines usually have a higher compression than turbo engines, id say get it looked at by a mechanic, it wouldnt hurt to have a compression and/or leakdown done on it at least this may give a little comfort as well.
Also there is a couple of things you could check, intercoolet piping and joiners.
Good luck with it
Good luck with it
Hi DA21 !!
I'd like to know more about your car (if that's ok?)!!...sounds hot and interesting!!!
Superspit!
I'm having a similar problem, I checked the ecu codes and got #11, and #21, crank sensor, and ign. circuit. My engine is a RB20DE conversion to DET and my problem started very similar to yours. Check to see if you have any fouled plugs, my #6 cylinder is not firing at all although the coils and plugs, etc. are fine.
If it cracks between two pistons u wont lose any water or oil it will just have bad compression , u have tried just about every other problem just other thing to look at
Hello,
Just a few suggestions..might have been covered but hope I can be of some help
No noise from the fuel pump.?...could be on the way out.
Fuel filter could be blocked....how does she run at idol?
Could one of your injectors be cracked or become faulty after the knock?
if you have checked these...take it down to a workshop.
Cheers Tekin
hi guys keep the comments coming.....
ok possible it could be blown head gasket...might be somethign to look at last id say
fuel pump is making normal noises...fuel pressure was pretty good!
injectors...very likely i would say...its definatly possible some are clogged
what do people think regarding a timing belt jump???
  • 5 weeks later...
    • Sounds like the solenoid might be cactus, if the solenoid trigger wire was still attached (and it was just the main power to the starter itself remove). Just to provoke Neil haunting me for the rest of my life... Have you tried tapping it with a hammer while someone switches the key to start? This might work for the fuel pump too... šŸ˜›
    • I need help dealing with an engineer who is massively overcharging me for an engineering report on my modified, written-off Jeep to get it roadworthy. šŸ”¹ Initially, he quoted me $3,500 - $4,500. šŸ”¹ First invoice: $5,315 (already above the quote). šŸ”¹ Second invoice: $1,375. šŸ”¹ Now, he has sent another invoice for $3,100! This is way more than double what I was originally quoted. I feel like Iā€™m being ripped off. Has anyone dealt with something like this before? What can I do? Any advice on how to report him or fight these unfair charges? Would really appreciate any guidance! šŸ™ Am in Adelaide.
    • I dunno man, that VX S with 200,000 k's is still hanging out for 1.5 I reckon the R34 is the better buy, personally.
    • Dang, doesn't even include on roads.
    • Only in a market where OBD was a thing. The rest of the world was quite happy to let the US EPA only affect US cars for quite a while. The* problem with datalogs is that unless you are very familiar with what every trace should look like, on their own and as an ensemble, you can and will see weird shit that can and will lead you astray, not realising that what you are seeing is the normal consequence of various transient inputs. *Really, "a" problem, as there are of course many other problems too. Look, these cars are so bloody simple that if it is missing or stumbling, the obvious thing is to break out the old mental diagnostic list and just go do all the things that you know you should. After proving that the plugs are clean and sound, ditto the coil stalks, coils, loom connectors, etc, and then making sure that there is fuel pressure at about the right numbers (while driving!, not while sitting in the garage free blipping it), then maybe you go looking at AFM voltages, manually testing the igniter, putting a scope on the CAS, etc. Then you're into pulling the injectors for a spray pattern look-see and perhaps a clean, squirting carby cleaner around the inlet manifold looking for leaks, and all the more annoying and esoteric, but still common as muck faults that these things have. I wouldn't ever bother looking at the trims, as they are usually bullshit on these old clunkers anyway.
Ɨ
Ɨ
