Hi I'm trying to override the factory boost solenoid thingy. I cannot find the solenoid, I have an SII r33 rb25det in a 240sx.
I want to ground the solenoids ground wire permenatly as done in the DIY section, however I cannot find an ecu pinout that shows exactly which wire it is. Can anyone tell me where this darn wire is? Thank you!
you probably dont have it
the solenoid is drilled to the wall of the engine bay in a skyline
easy way to override it is to just run a vacuum hose from the charged piping straight to the wastegate actuator
I just did that, it still does the same thing, goes to 5lbs then evntually to about 9lbs of boost. Is this some form of boost spike? Or is there a hidden boost solenoid built into the i/m or is everything just normal?
Also when I hit boost cut wil the car cut ignition/fuel or both?
if you have an FMIC and exhaust its going to creep a bit... mine was creeping to about 9 lbs after installing mine. Its normal.
So if i put a boost controller on could it creep any higher?
if you don't leave it completely loosening, if you add pressure to the MBC's spring it will increase the boost pressure. I wouldnt run more than 11-12 psi. After that its hit or miss on how long the turbine wheel stays attached...
    • Shit thing to find eh? I guess the big issue is that whatever "fix" you do now, it might slow the rust down but won't fix it. I just wanted to add that in no way is fixing sheet metal in 3 dimensions the place to start with welding....that is a pro only job because its too hard to work out where things should be, let alone doing a clean enough job that it can look OK and still be strong too.  I needed to get a new rear quarter panel on the GTR and it took a pro weeks to get the old one off cleanly, new one on in the right place and looking somewhat like it should have with most of the previous connecting panels in place. Gluing a couple of bits of metal together with a welder in the garage is doable, but that is totally different to doing panel  replacement
    • This seems to be a very popular swap since all the turbo skyline prices went through the roof! I'll let someone more familiar chime in, but I understand that yes you probably want to swap the loom in to swap out the auto TCM stuff. You should not assume everything just plugs in either, you need to check at least the ECU wiring diagram for any differences at the plug at the left headlight and probably the ones near the ECU that join the dash loom too
    • hows it fellas, my first post here which seems crazy cos half the forums i read are like the same age as me haha. to make a long story short ive got an r34 sedan (rb25de neo auto) which im swapping to a s0/s1? rb25det, r33 big box and nismo gt pro lsd. i have the motor and gearbox all bolted up outside the car, old motor and trans out. i bought the motor with stock ecu and loom, do i switch over to that? or will it be easier to get a r34 manual ecu and keep the loom if thats even possible.  also engine mounts look different, anything else thats different or incompatible? cheers, hope this all makes sense Paddy
    • att.4QNbuJlz_gNZPFBGFqeEvxSUHXkGt7z40V59MrtXTPg.mp4
    • Plan on the day will be to park trackside. Depending on space availability we will try put a small shade tent and a few of the cars on top of the hill inside turn 3, this is an easy to get to parking area with views of Turn 2, Turn 3, Turn 4 and Turn 5 and limited other pieces of the view around the track. IMPORTANT NOTE! One consideration from previous years is from memory the trackside parking sells out before the admission tickets, for that reason I encourage anyone planning on coming to buy tickets for parking now via the official website; https://www.worldtimeattack.com/ The type of parking you are looking for is 2 Day Park & View (Access Around Venue) Vehicle Pass Only Please note this does not include admission to the event itself, remember to grab that also, and kids under 12 get in for free!
