Alrighty
So I have a spare VP S2 3.8L V6 Commodore motor sitting down the back.
It has NO alt, NO PS, NO LOOM, NO ECU
It has been stripped and just "placed" back together (Needs a rebuild)
Has basically everything else with it
Also have everything that's required for a manual to auto conversion on a V6 (Torque convertor, bell housing, interior parts, shifter, tail shaft)
This all came out of my old VR V6 Acclaim.
Gearbox has dropped something. It still drove, but much more then 1/4 drive and it went majorly slipping through 1st and 2nd (no drive at all) Even a couple of times in 3rd if I went to overtake on the freeway, was quite dangerous. So needs a rebuild.
I have my two old rear tyres (no rim) One is on tread wears, the other has about 2mm left to wear.
Suit a stock VR Commo rim. (205/50/15 I think, or 225/50/15 I think, not positive)
I also have my cannon that came with my R33 for sale. It's in good working order, needs a polish.
Reason for removal: Needed to get the car a touch quiter (Was only JUST legally over because of the rest of my exhaust system)
3" in, 3" out from memory
So, engine: $100 (Make an offer)
Gearbox: $100 (make an offer)
Rest of the auto gear: $100 (Make an offer)
Tyres: Buy something and if you want em you can have em.
Cannon: $120 (make an offer)
Okay, SMS me on 0406 962 347 or PM me on here.
The first 3 items I'm quite negotiable on, basically throw me an offer and you'll prob be able to come pick it up.
Quite urgently want them gone (They've just been sitting since they got pulled out, want em gone now, I need that side of the garage clear)
Reason for sale: They're commodore parts (Mainly), I don't have my commodore anymore, and I'm no longer going to be building my buggy, hence they're no use. I also need my garage space... :whistling:
Make an offer, any offer.
https://www.sau.com.au/forums/topic/167757-engine-gearbox-muffler/
Alrighty
what size is the cannon?
    • See my post here If you put the Haltech in, you won't have to worry about any of that. And, in case you're worrying about my lack of credentials in doing your exact swap, I put a Neo in an R32. There has never been a stock boost solenoid near my car and the Neo's ECU has never cared. Nor should it, because it is electronically impossible for it to care.
    • That's 100% wrong. Did you wire in the boost sensor? If you did not, then that is 101% your answer. Neo ECUs do suck a bit.
    • Hello, I'm trying to make this thread basically the thread with all the answers to common questions regarding specifically the RB20 DE NEO + T engine, that comes in the R34. Answers will and only should be provided by those who have done this conversion or actually have some relevant real life experience please. Please feel free to ask questions in the comments if you have any so other members can answer. I feel like this thread is really needed, especially with more Americans buying (unknowingly going to regret it too) rb20 neo r34s. My first question being - What do you guys use for tuning? I have purchased a haltech elite 2500 Plug and play kit for the rb25det NEO because the ecu plug is the same, but I am unsure if any of the pins would need to be repined to match. Second question that I see asked very often - After this conversion, did you install the boost solenoid/ actuator? I see many people doing a + T setup on their rb20 NEOs while running stock RB25DET NEO ECUs with no tune. I am wondering how they are going about doing that and consistently abusing the car because many of these people have had these untuned setups running for a very long time. That was my original plan, but my engine cuts out at 5 psi of boost using the stock ecu with no tune and no boost solenoid/actuator.
    • interesting. ive read and heard otherwise over the past year. ive been doing this +t conversion on a rb20 neo using all oem rb25det neo parts including the ECU, and im having engine cut out issues when I hit around 5 psi of boost. Everywhere/everyone ive asked has told me its because I never wired in a boost solenoid/actuator to the ecu, so the ecu isn't getting the right signal once it hits 5 psi of boost, causing the engine to get shut off.
