First end was Ok for length of threaded section, but the tapered pin was too small.
Second was OK for pin, but too long in the threaded shank. So out with the angle grinder and....
the threaded section was only threaded the same depth as the shorter correct one, so now the rod bottomed out
before I could get any semblance of alignment. If I cut the rod off I would still been stuffed.
So on to the LHS and used up all the available adjustment so the car at least steers reasonable well till I can get the correct end. Steering wheel is about 150 degrees off, but drives straight no hands.
The overall length of the threaded shank including the round section is 117mm.
Tapered pin is 18mm dia. on large end and about 14mm dia on the small end.
I,ll try and find out off what vehicles the ends came, and post it up.
Tomorrow I now have to get another end plus two new tyres caus they stuff very quickly.
https://www.sau.com.au/forums/topic/167760-tie-rod-ends/
This misadventure has been the most frustrating episode of reparing any vehicle since I started (truck) driving at the tender age of ,yes, fourteen. Things were tough in those days.
Three times I've tried to get a simple tie rod end. Three times I've been supplied the wrong thing.
I've come to the conclusion that a lot (most) of the so called "parts suppliers" have not got a f**king (fornicating) clue.
While they have half cuts and wrecks and bits and pieces of 32 33 &34 Skys lying around, they do not seem to understand
for example that there is a difference between a 32 GTST and a 33GTR, or a 34 for that matter. One had two S1 half cuts.
I drove a 3 hour return trip only to discover that the wrong bit had been supplied. So far I'm about $220 out of pocket and
tomorrow I'm on another three hour return trip to get the right bit.
I just hope that all the Saints in Stagea heaven are on my side tomorrow.
I might also add that Mrs. 66yo is giving me f**king heaps over this.
Why didn't you buy a f**king Bombadoor and gas it?
Why???
https://www.sau.com.au/forums/topic/167760-tie-rod-ends/#findComment-3106872
im 999999.8798% sure the entire s14 front tierod and ends will work
or z32
let me do some part number crunching and ill get back with you in a minute
give me 24 hours to find this thing
i cant find it on the cusco or JIC site.
ill get you a definate what chassis crossreferences by tomorrow night hopefully.
https://www.sau.com.au/forums/topic/167760-tie-rod-ends/#findComment-3106896
I finally got the right one today. It came offa rack that had no identifying numbers or marks.
It has been very frustrating and I want to thank all the members who helped.
So tomorrow I get it installed and a couple of new tyres for the front.
Next week the timing belt etc.
I must learn how to post pics.
https://www.sau.com.au/forums/topic/167760-tie-rod-ends/#findComment-3109702
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
    • Nah, I much prefer colour matched Talking about colour matching stuff, the new/used boot lid turned up, all painted up perfectly......aaaannnndddd, it's for a power retractable hard top, not a soft top.....LOL They are now sending a boot to fit a soft top.....,  whilst frustrating, life is like that sometimes, sometimes you just need to dodge, duck, dip, dive and, ummm, dodge.
