That what the car stands are for, so u can safely work under them as they wont collapse like a jack can.
theres no real difference in safety with working under a hoist or car stands, they both go under the jacking points of the vehicle
just make sure you jack the car up on level ground and have all the stands equal hights.
I am very concerned with the safety of myself. Dropping my car is my biggest fear. From reading my replies to the trolley jack thread, you can see i don't skimp on safety.
I have 3 big trolley jacks, and 2 small ones.
Normally when I jack the front of the car up, it gets one big trolley jack in the middle of the member, 2 stands on either side of the big jack on the member, and 2 small trolley jacks under various points. I would put the others under there too, but then there's not enough room to work on the car.
If I have the car up on 4, I use 4 stands. I still have one big jack in the middle of the cross member too. I also chuck a big jack under the diff, and I chuck the 2 small jacks to the side. I'll just use the last big jack under something random just for safety, incase if my other 4 stands and 4 jacks fail. hahaha.
aye carumba manwhore!! that made me dizzey!
well i bought my 4 stands and a 2.5t trolley jack so i could do my g/b oil and fit my exhaust myself when i get it too. so i might put it up on all four to see how it looks when i do the g/b oil - if i feel unsafe, i'll bring it down onto two stands. my drive-way is pretty much level....
I certainly wouldn't use only two... four is the magic number!
You really don't EVER want to be under your car while it's being fully or partially supported by a jack.
I know how you feel though... tiny little surface of the stands holding your car up, and it looks dodgy the first few times you do it... but a mate of mine helped me get over it.
Under his car, bracing against the wall, with a breaker bar trying to undo something... whole car shakes around on the stands.. but it doesn't budge. Same thing getting the gearbox out of my car.
So now I do the same.. jack it up, 4 stands, then release the jack a little so it's about 1cm from the diff or whatever you're jacking from, and then give the car a bit of a shove. It won't budge. ;o)
If u are changing the gearbox oil just jack up the front , by time time u jack the back of the car up u could have the oil out
wouldnt jacking the car up on two stands make draining and filling the gearbox oil uneven because the car is tilted
having 4 jacks and 4 stands under your car will restrict the amount of room you have to move around, sounds kinda stupid if u ask me. if your that scared to get under a car which is on 4 car stands then make friends with a mechanic and ask to use their hoist on a sat or weeknight.
if the car is on level ground and the stands are in the right positions then you should not have a problem.
If you are really worried about it get a real spare or even another cars spare and sit that next to you under the car if it manages to fall off the stands spare will give you a chance as the car wont fall so far when changing tyres on the side of a road this is also a good idea as disks can get easily damaged if the car falls of the jack.
4wheel drive wheel or nice wide rims are of course better
I have the equipment, so why not use it?
Let me tell you, if i have the whole car up, 4 jacks and 4 stands hardly takes up much room at all. You're literally talking 1 jack and 1 stand per corner. Plenty of room where it counts.
I have not found room to be of an issue.
I would say yes, it is overkill, stupid no. If I hvae the equipment, why not use it to make it safer (provided it doesn't get in the way - which it doesn't).
I still haven't figured out where to place the stands for the rear of the car. This is on an R32 by the way. I've used a trolley jack on the diff before to change the wheels, but I've never had to work under the rear of the car so I've never lowered it onto stands. Where do you place your stands for the rear of the car?
dont think really good idea to use the diff as the point to jack up the car...there is a centre point just in front of the diff to jack rear up..if car is too low then...drive on couple pavers to bring the car up abit....I did my G/B oil with ramps to the front only, thought about jacking the back up and using stands to level but didnt need too. 4 stands is the go and have a jack or 2 in some key points, pre load it abit, just in case something does happen to the stands the jack/s will take up the weight
yeah 4 stands is pretty dangerous......
seen it fail before....
one good tweak of the wrench and it could be goodnight irene!!!!
best find a mate with a proper hoist, or use just two stands where at least there are two wheels on the gorund to give the car some balance......
you could always just test it by putting it on for stands and just leaning agianst the car :)
Why isn't it a good idea to use the rear diff? It's been recommended by many people on this forum to use as the rear jacking point. I've had a look at the manual and I just realised the picture shows jacking point is indeed slighty pass the the diff. I've always assumed using the diff was fine. Well it's been ok for me so far.
    • it takes so long to get things done but ... they are nearly there and we hitting the track soon again  So - at Perth Festival of Speed the car unfortunately had a decent off, wasnt me driving, wasnt the person drivings fault. Long story short car got sent very fast towards the wall without the control on throttle from the driver input and a disaster was averted but there was damage that needed to be fixed - carbon busted and alot of bent bits The splitter got munched and had to go back to get fixed - took a bit to get it there, fixed and back but got a surprise package when a new double element higher DF splitter came back - nice surprise !  and first person to have one     At a car show I took the car too some punks stole one of my carbon indicator blanks and stomped on the other so had to get a new set of headlight / indicator combo from tops stage so got front fender vents as well to put in the order     While all this was happening the new MCA golds turned up and did some fiddling around with those   Put in the flappy paddle system and clutch lockout wiring/ system   We have also put shorter gearing in top top it out at 300 kmph in 6th gear  where previously I held 5th to 282 at SMP and 277 in Perth   Looking for better control and faster acceleration     I wasnt intending on doing pedal box I was managing with the brake master replacement system I had going on and adjusted std pedals but on applying the clutch switch to the old system we found the *insert technical word here * bar that goes from the pedal to the master was bent about 40 deg and about to snap = lucky find otherwise be a bad bad time - discussion was had about getting a custom bar built to withstand the load but in reality it was time      making any suspension, wheel or anything adjustments to date has been a nightmare - aero off, adjust, check and repeat - time consuming and hard - short of going full airjack system we fashioned some external manual car lifts this will make life a million times easier     All the bent framing, some intercooler pipes and other has been fixed and replaced and after 6 months I finally have the car back at home in my control so its get to work on it, set ride heights, wheel align and will start track testing again soon   So ultimately other than a few flashy bits nothing actually looks likes its been done but in reality alot has. Typical   We'll see how all this goes
    • I'm far from an expert, but for sticking bits of metal together occasionally I got a MIG, the biggest one I could get with a 10a plug (because while I have some 15a GPOs around, they are not everywhere).  Also, because I get through SFA, I just buy the small disposable gas bottles at Bunnings, I'm not opening a BOC account to get through 1/10th of a full size bottle each year
    • FWD is different though.
    • Ignore the BOV / recirc valve question. You have an NA and shouldn't have one. If there magically is one though... It should be removed, though it shouldn't really effect it in the way one will for a turbo motor with it venting to atmosphere while running an afm.
